Tool bar selection of tools is broken when running with an iPad as a second screen
Using an iPad as a second screen (MacOS native feature) (ViaCAD is still on the MacBook screen) using the tool bar selection → press and hold and then move right to select a new tool, is broken. The tool menu opens, but you can not slide right to select a new tool. Basically the same issue that arose in ViaCAD 12 all the time with the new OS. It works fine when you disconnect the iPad as a second screen.
Running release 1616 and still occurs in beta 1620.
Dwayne
Hi Dwayne
That’s the same issue you have with a MacBook and an external monitor too. I did a search on Google re Rosetta2 translation issues when I noticed this, and nothing came up about an external monitor, so I think it’s the way the legacy code in SharkCAD is handling external monitors/screens possibly not following some newer Apple guidelines or maybe there is a mouse action bug. This one has been around a while, not sure why it’s taking so long to fix, or whether it’s just macOS, but your feature uses an app called “Sidecar” in Apple speak, and it’s been around since macOS Catalina.
Ya, just read through your post on basically the same issue. Sad that this has existed for a while and still is not fixed. I came across this because of the need to perform a screen share and used sidecar to utilize my iPad as a second screen for the conference screen. Made the session very difficult without the tool bar working properly; had to manually pop through the menus to orchestrate the changes. Hopefully this becomes a priority and is fixed since multi-screens on a desktop are the norm now.
Ok, further testing: It has to do with the scaling of the second screen and its position with respect to the primary display. It appears that ViaCAD / SharkCAD gets confused where you’re clicking when the secondary screen is anywhere but perfectly aligned left side or right. It can’t be lower or higher. It also affects where the program title bar is and where the canvas opens initially. It defaults to what the positional location of the second display is telling it instead of understanding which display it is being used on.
@dmers7 wrote “It can’t be lower or higher.”
Great spot, that does make sense, and that is my use case too, as the MacBook is on the desk and the MateView is naturally higher and on its base/stand, so it just made sense to make the trackpad cursor move diagonally to get to the next screen.
Once I open and close SharkCAD a few times, all the title bar and page layout is saved correctly, but I still have the toolbar issue, which has a mouse action error bug when you want to expand the toolset from its on display position.
I’m guessing your new information will point to a debug solution for the screen layout, as well as possibly displaying the SharkCAD menu bar permanently***.
BTW The MateView is a 3840x2560 4K 4:3 monitor which has a different aspect ratio to the usual 16:9 Apple standard
Just an update re Toolbar Mouse Over, what’s really interesting, two of the toolbar selection do correctly respond to mouseovers and mouse clicks, so maybe this will give some pointers to debug this issue.
PS @dmyers7 I did say earlier that was only when using as an Extended Display. If you use as a Mirror there is no issue with mouse over and clicking subsets of the Toolbar, but I haven’t tried letting the scaling of the external display to get a fix
@24c It definitely appears to be a scaling issue & position issue. Hence why you can get 2 of the buttons to work and then the others are not where the interface thinks they are compared to where they are displayed.
I have also found that if you maximize the drawing canvas when using only a single screen, the selection of features with in the design gets all misaligned to what the cursor thinks it is clicking on. You have to minimize the window and then restore it to the standard size. Oddly, if you resize the window manually; say smaller to view something like notes why you draw, that works perfectly fine.
@TimOlsen. Hopefully these issues can be resolved before final release. If there are additional inputs your need; here to help.
Thanks,
Dwayne
@dmyers7 Well whatever it is it’s a nuisance as I decided to move away from a desktop model (27" iMac & 27" LED display which didn’t have this problem, both monitors were the same resolution)
However, re my last post on this thread, since re-opening SharkCAD and switching display settings from Mirror mode (MateView resolution mirrored), even those two toolsets are not working now aka there’s no mouseover action or mouse action response, so definitely some variables here. :slight_smile:
Have any Windows users reported a problem say when using Presentation Mode?
Just for info, no fix in build 1621
1623 - Still broken
Can you post your punchcad.log files? The log contains sizes and positions of the extra monitor.
/User//Shared/punchcad.log
Hi Tim,
This is really an odd one for me, as I just went to get the log files, and had to open SharkCAD 1623 and the toolbar is working on my MacBook screen, whilst I have the forum opened in Safari on the extended screen.
Really strange and I’ll try and replicate the faulty behaviour by switching SharkCAD to the extended display & post these logs.
punchcad.log.zip (1.57 KB)
Hi again,
Moved SharkCAD around desktop looks like this, but cannot get SharkCAD “status bar” to move to extended display. Interesting after first jumping upwards and detaching the tool strip when selecting a new tool to the right, the toolbar behaviour on mouse over and click is correct now.
punchcad.log2.zip (1.6 KB)
Attached
Dwayne
punchcad.log.zip (1.56 KB)
punchcad 2.log.zip (1.3 KB)
Not seeing anything about monitors and resolutions in those files, but hopefully that gives you what you need.
the first Zip is from 1623
Thew second Zip is from the released version 1616
Let me know if there is anything else you need,
Dwayne
So during this same session, if I place the position of my second monitor below my MacBook screen, ViaCAD acts fine. Place it above and it breaks the toolbar press and hold selection again. I can’t find the “sweet” spot on the left and right either, so that also still breaks the toolbar.
Dwayne
My extended display MateView is on the left of my MacBook which is the “Main Display” in the Settings>Display preferences, and the SharkCAD “status bar” is locked to the MacBook, and the behaviour on opening SharkCAD is like the video (480p for size limits). On first mouse clicking the toolbar, the toolbar strip detaches from the main block, but then on subsequent mouse overs disappears, and then starts to behave normally (this was different to earlier builds AFAIK) with mouse clicks (10 secs in). The new window is always at the bottom of the screen, but you can move this, and if you save the file and quit it can remember that new position (but not always)
If I select the MateView as the Main Display and the MacBook as the Extended, the status bar is about a third down from the top of the MateView display, but the Tools palette is non-functional on mouseover and clicking other than the default settings with the exception of the “Render Camera” & “Walkthrough” tool palette options. If I drag off a tool palette strip, the mouse over and mouse click options are available.
At the moment my status bar cannot be moved to the top of the desktop, at it appears SharkCAD window area is constrained by the default MacBook resolution with bottom left being 0,0
punchcad.log3.zip (1.57 KB)
The video didn’t want to upload despite reducing it down to size, this screenshot is when the MateView (native 3840 x 2560 px) is being used as the Main Display, and the MacBook is the Extended Display.
After re-opening, resizing the drawing window onto the Main Display aka the MateView, the Tools palette has started to work normally. The status bar is full width at the top of the display, screenshot is displaying 1920x1280 px, which is expected in macOS (3840/2 x 2560/2)
UPDATE To take the screenshots I minimised the SharkCAD window, and when restoring the Tools palette was not offering the Tools options like it normally does. It appears that minimising the active window and restoring breaks the normal Tools palette behaviour. However working on another app on the MacBook (extended Display) with the restored window still displaying on the MateView, and activating again by clicking in the SharkCAD window, has made the Tools palette work again. Really odd.
Log attached
punchcad.log5.zip (1.63 KB)
