Trying to replicate this behaviour by minimising the window, and getting the Tools palette fault, and then getting it to work again, is not as simple as I thought. Clicking on the other screen doesn’t restore it…
clicking on the SharkCAD icon in the MacBook screen dock does.
I have two docks one per screen but only the MacBook one is on view) restores the Tools palette, so
if I minimise the window on the Main Display (MateView) the Tools palette functions correctly,
if I restore the window on the Main Display it doesn’t
if I click on the SharkCAD icon in my Dock on the MacBook (Extended Display) and move the cursor over to the MateView the Tools palette functions correctly again
this is repeatable behaviour
PS I need to edit my previous posts as I got Extended Display and main Display modes mixed up
OK, it appears the dock in the Extended Display is more active than the Main Display one, as I noticed the minimised SharkCAD window from the Main Display it was reducing into the Extended Display dock as well.
if you restore from this dock (Extended Display) the Tools palette behaves normally.
if you leave your desktops open on return the Tools palette stops working correctly, but can be restored by clicking the SharkCAD icon in the Extended Display dock (the SharkCAD window is open on the main Display)
I can see my iPad display and move the SharkCAD active window to this, but I cannot maintain the connection long enough to move the Tools palette over and test its function
This is the display issue done for me, not the OP with his iPad is as good as it gets right now.
I can’t get the iPad Pro to connect reliably, so haven’t been able to test this further.
I logged out and in doing so it seems I only have one dock at the bottom not two (one for each display previously)
it seems with only one dock and the larger MateView as the Main Display (I think if the menu bar is at the top of the display it is the main one in macO) and any other displays resort to an Extended Display mode automatically) the problem with the Tools palette is no longer there, even if minimising and restoring active windows, or having another open drawing on the other monitor and switching between these is a non-issue.
I will try and get another dock up and running on the other display (MacBook) to see if this breaks the behaviour, as well as get the iPad connected.
@dmyers
Unfortunately my iPad Pro doesn’t support USB-C but should work according to Apple requirements. The Lightning display adaptors are HDM, butI I have since updated to iOS 16.4 & a bug fix 16.4.1, and surprisingly the wireless connection is stable and if I drag the SharkCAD Tools palette to the iPad screen along with the active drawing window I can mouse over, click and draw in SharkCAD.
I was also able to see the iPad display in Settings>Displays and arrange to suit.
Functionally working now, but not sure I’d have a use case for this with SharkCAD, but useful for other apps I might want to keep an eye on.
It did work for a short time, took a screenshot, but then it reverted to losing connection again when I tried re-arranging the display ( I think the iPad defaults to the left of the Main Display, if you have an extended display on the right). I also think it is a macOS Display setting clashing with using the trackpad and mouse to control the iPad, and using the iPad as an extended display. I tried restarting the MacBook and iPad but couldn’t get it back. When I dragged the active SharkCAD drawing window onto the iPad, along with tool palette, on restarting the preferences that SharkCAd saved for the active window position were in the iPad location, and I couldn’t drag and hold the window back onto the MateView or MacBook screens.
I’m still trying to replicate the actions I did to get it working. I was able to select a circle tool and draw a circle on the relocated SharkCAD window but usually tool dropdown selection only works on the main display. You don’t get an option to make the iPad a main display, but maybe you can drag the menu bar over which does the same.
PS When I go into Settings>Displays in macOS I can see two iPads in the arrangement, one can be butted up to the adjacent display, the other can’t. I think this is related to the two different macOS technologies available.
In Settings>Displays I also have the option to use AppleTV, besides the iPad, as a display (which is connected to a Samsung 40" screen), and in doing so, I can move the active SharkCAD window and Tools palette to this display, and select other tools from the Tools Palette, and draw on screen using the trackpad and keyboard on the MacBook.
The iPad just flits in and out of connection, despite restarting (it works OK at first) but this might be Parallels (VM software) interfering and detecting the display as a Windows Presentation Mode device.
I have checked the pop up to ignore this device and remember my selection, but it still pops up regardless.
No go. The iPad and the Mac Pro M1P are both up to date. ViaCAD 1624. Same as above. Arrange the screen below my MacBook screen and it acts fine, move it to the top or sides and the toolbar doesn’t know where the mouse is with reference to the opened toolbar menu. You can pull it off the toolbar and it is fine to click directly on a tool, but press and hold fails to allow you to slide the mouse to the right and select a new tool to show on the toolbar.
Not sure what is happening, but here are the screenshots of the display arrangement (MacBook Pro was right of MateView), and you can see the two types of iPad displays in the arrangement.
The window that worked was the image with the thicker black bezel, whereas the iPad icon with the thinner display bezel is the “use as extended display” variant
The first image left in this post is what I saw on the iPad screen.
Since I can’t change the screen resolution of my iPad as a secondary screen, I varied the resolution of the MacBook screen. When the MacBooks screen basically matched the iPad screen resolution, the toolbar selection basically worked again, until I moved it to the iPad screen and then the pop-out menu was mis-registered.
