ViaCad V15 Lineweights
I have my line weights set at 0.35mm for hidden detail, dimensions and any other references, outlines, borders and text are set at 0.5mm. when I change line to larges sizes the screen recognises that change, but regardless this change is not reflected in the print the lines are generally invisible, but outlines, hatches, leaders and dimensions are printed, but don’t appear to show the line weights these are set at and are of uniform thick lines. Are there any general settings globally or in layer that I can set to remedy this or is there a fix?
I always use pixel-based line widths, generally just 1 px. I print the dimensions in a different color. The correct print layout is automatically determined within Draw Views. Changing it afterward is usually not possible. I haven’t tried printing drawings outside of Draw Views yet.
