We want you to test the Import / Export restriction for trial.
The Import/Export restriction applies only to non-native file formats. You can import or export up to three non-native file formats. On the fourth attempt, a restriction message will be displayed.
Download and install TurboCAD Mac 17 from the following link:
OK, so you are going to restrict the trial version in the future, and that’s what we are testing.
As someone who uses SharkCAD Pro for 3D printer modelling and laser cutting profiles amongst other things, It’s very easy to reach this limit of non-native file formats (DXF, DWG, STEP or STL). I did try to use Save As > New Filename, Open this and then try to Export but I got the same message.
It would seem the restriction is smart enough.
