USB-C External Display in macOS Ventura
Hi
I am using v14 (build 1613) with my Apple Silicon MacBook Pro and macOS Ventura, and I have had display issues using an external display in extended mode. Obviously using Rosetta 2, but just asking if anyone else has had issues with tools not selecting (workaround is to pull them off and litter the screen space) or opening two files and one window disappearing behind the other?
I’m just downloading build 1620, and I’m not sure if this is fixed yet hence the post. If not I’ll grab some screenshots to highlight my issues, but it might be something to do with Stage Manager settings.
Kind regards
Hi Mike,
I never got it work with a temporary external display.
I tried many brands and different connexions.
It’s a mess when I plug it in, and another mess when I plug it out.
So I use my external 30" displays for other software, and work on Shark on my 16" laptop…
JL
Thanks JL,
That’s interesting all the same, and at the same time disappointing. I deliberately didn’t get a 16" model, as the 14" was more flexible re power supply options, plus the chipset could drive external displays. I never really had an issues using my iMac and an external 27" display, so I was a bit surprised to see this, and just thought it was a macOS Ventura thing. :slight_smile:
I’ll keep plugging away and see if I can alter some System Settings to understand the issues a little more. I suspect it’s a drawing/window issue that’s changed in macOS that needs a software tweak or possibly a Rosetta2 bug.
Thanks again
Hi again,
It would seem Stage Manager stops the Tools window going to the left edge of the screen, and it sits about 240px to the right.
Turning off Stage Manager allows it to go to the left side fully aka 0px.
The cursor selection of “layered” tools is still not working as it should, you can move the cursor over the tool you want to select, but clicking on it does not change anything.
Short video of the issue, I’m clicking on the mouse and nothing changes when I try and select another circle tool, but I can drag the “circle” tool selections off the Tools window and select normally (not shown)
Cheers
Hi again just to clarify, if I set the external monitor to an Extended Display or Main Display in macOS System Settings>Displays the behaviour is just the same on the native MacBook screen until I disconnect the USB C screen cable when the issue disappears.
14" MacBook Pro M1 Max macOS Ventura 13.2.1 & Huawei 28.2" MateView
Hi again,
So I can get the MateView external display to avoid the issues I’m having in SharkCAD. In System Settings>Displays I set the MateView as the “Main display” 7 The Built-in Display as a “Mirror for MateView” and I can select the additional tools behind the Tools palette now.
If I use the “Extended display” setting the issue returns.
Cheers
PS Stage Manager doesn’t appear to work in mirror mode even if “Displays have separate Spaces” is checked
PPS This might help you JLM??
Thanks Mike, but “mirror” doesn’t work for me : it put the top prompt bar of Shark in the top third of the screen, on both monitors.
See my screen grab…
Extended doesn’t work neither.
I complained about that years ago :
Forum monitor issue LINK
salut jlm,
That’s what happened to me when I first plugged my display in and opened SharkCAD after using my MacBook.
I had to resize move Shark around, and then save my work, to for Shark’s preferences remember the window location.
I will try and replicate the fault again, and see how I overcame it, but once Shark remembered the new window position I did not have that problem, just one if I had two projects open in a window each, when I tried to move of zoom to fit the window, the drawing was offset to the top right.
amicalement
mike
bj jam,
OK, so I reverted the SharkCAD Settings to “Factory All”, Quit Shark and re-opened and I got my initial problem, like yours I think. I am in Extended Display Mode, with the MateView as “Main Display”
The workaround is maximise the Shark window using the green button, and the Shark “top bar” will be part the way down the screen still, but quit Shark and reopen (I did save an untitled project aka a line), and it will go to the top again. However, the maximised window from before will be at the bottom of the screen, so manually move this up,( draw something & save this drawing) and quit Shark again.
When you re-open the window and Shark bar should be both at the top of the extended screen… however for me I have to tear off tools so that I can select other than the default ones.
This is just an update to my SharkCAD glitches when using a MacBook and an external display.
I’m not sure if anything has been done in previous updates, now on build 1624, but since I made the USB-C MateView monitor the Main Display in macOS’s Display Settings, my MacBook Pro an Extended Display in the same (no arrangement restrictions needed), all has been more or less useable. Ok, not at strictly at first, because it takes a few open and close cycles before SharkCAD’s remembers its new display preferences aka my window locations on the MateView especially if I have been using SharkCAD on the MacBook away from my desktop. If I unplug the USB-C cable without using SharkCAD on the MacBook, it will remember the MateView settings, even if SharkCAD is open on the MateView. The window just transfers to the MacBook.
I now have Stage Manager working on the Main Display too, and SharkCAD minimises and maximises no problem, the only issue is sometimes (possibly a sleep mode thing) when it does maximise from Stage Manager the tool selection “status” strip (the one just under the Apple Menu) is missing. However if you quit SharkCAD and re-launch it reappears in the right place.
I’ll have to wait and see what happens when I add another monitor, but even adding an AppleTV linked TV screen doesn’t break things, so I’m hopeful my SharkCAD functionality won’t be broken.
@jlm does yours now work?
