… As established in Dean’s car modelling thread, rounding when there is a single surface on one side and multiple surfaces on the other … doesn’t see to work, and appears to be a significant omission !
[personally I would stitch it into a solid - then both rounding and shelling to thickness is easy]
In this case, it does not matter. It is important to me to understand how this can be realized. What techniques and tools can be used here? This should be something like this.
This works correctly only with four edges. In my case, the bottom edge is much wider than three top edges
Blending failures are usually due to transitions and curvature related issues. Attached is an example where I first blended the vertical edge with a high value (15mm) and then two more fillet blends with 4 mm.
If you do multiple radius blends as part of a network, it’s usually best to do the largest one first.
Many many thanks Tim. This is a very big advance and it’s very close. I decided to make more cleaner surface. Unfortunately I can not close this hole. I used Tangent Cover Surface.
In addition, not all surfaces allow thickening. VCP file is attached.
or are you just trying different stuff (as any of us might) on your quest for a solution
Trying stuff. Once I saw fixed width work, I wanted to understand why constant didn’t which included attempting to manually blend. Manual blends seemed to fail with the same surface so I untrimmed/show points to take a peek at the underlying surface.
Next will check with Spatial regarding what kind of options are available for covering.
