Remove fillet
Can someone explain or point me to a tutorial that shows how to remove a fillet I added previously?
Hello
What are you looking to remove a fillet from a 2d profile or a surface or solid ?
Regards
Jason
I think it’s a solid. (But maybe it’s the surface I want to remove, fuzzy on surfaces). See attached. I want to remove the fillet from the rim of the “bowl”
SquareBowl.vc3 (122 KB)
Hello Shorton,
This is a very easy one because your part has history…
Go to the concept Exploreur -->Entities
And remove the feature “fillet”
When there is no history, the “remove face” tool works pretty well…
Another solution:
Select first the bend with the SELECT DEEP flash and press Delete …
Repeat it with the fillet. Part by part.
Thats all.
Thanks. It’s the inside the bowl rim I’m wanting to delete. I tried using the explorer entities but when I did it didn’t behave as I intended. I gor a 180degree fillet coming from the bottom to the top. I wanted it to just undo and leave the perpendicular edge as was there before the fillet.
That aside, can you explain how I would use “remove face” tool?
Dear Shorton,
Choose the remove face tool (picture)
Hold on the shift key and select each surface of the fillet, all around
That’s it…
JL
