With SharkCad Pro build 1641 program menus randomly becomes unresponsive. I have to restart the app to fix. Very annoying and it happens often enough. Anyone else getting this?
Claus
Claus
Hi Claus
I did some testing on the Sonoma beta and did not notice anything.
But after seeing your post, I’m going to go do some more testing.
You are using one monitor?
If you have steps to repeat please let me know.
Tim,
I’m on my M2 laptop using only an external Studio display.
yesterday I tried disabling the “automatic hide open windows when click on desktop” thing - and I did not have the problem. Otherwise maybe related to exporting and switching apps. Not sure, I’ll let you know.
Claus
It’s unrelated to the hide windows, it just happened again. While opening Fusion I switched to Shark and the file menu stayed on the screen, even in other apps and Finder, but was inactive. Had to force quit.
Hi Claus2,
I’ve noticed this unresponsiveness too, but it also did it in Picoscope (USB Oscilloscope software), and I’ll try and test it again tomorrow.
I too had to Force Quit
Thanks, good to know.
Claus
Just one question ! Can we install Sonoma ?
Did you see some conflict with Shark Cad 1641 ?
Hi,
I have seen no additional “glitches” with Sonoma vs Ventura and build 1641..
I have had no problems opening old files with Sonoma to date.
Using an additional different resolution monitor has the same issues
I’m also getting sporadic unresponsive menus. Have to force quit to get rid of them.
SharkCAD 1624, macOS 14.0, Intel MacBook Pro 13", no external display.
EDIT: Toggling the inspector or concept explorer via keyboard shortcuts is a workaround to unfreeze the menu.
Me too now @lightbulbjim, although I did manage to toggle out and had to force quit. The problem generally occurred when I closed the Tools or Inspector window.. Pretty frustrating as I was drawing a room layout, and I kept loosing it with the Force Quits… grrr I had to make regular saves. Also I imported a 700Kb PDF as an underlay to draw over, and SharkCAD was hanging between saves and opening the original file.
EDIT Updated to macOS 14.1 and no changes
Same here on Intel iMac and MBPro with Sonoma. Seemingly random freeze of menus. Maybe the error reports are going to someone who can decode them..
Tim, are you still investigating this? The issue is severely affecting working with the app.
Claus
Hello Claus
Yes, I can repeat the issue. But have not been able to find a correction yet.
The lock up is inside macOS making it difficult to track down.
So far it appears related to event messaging between our app and the OS.
Still looking into…
Tim, I will wait your GO for downloading Sonoma !!!
I found out a way to recover from the inactive menus. Open Activity Monitor and kill the process WindowServer. The screen will go black and the login window appears, but after logging in the menus have recovered. Do this at your own risk.
Claus
