"Loft Surface" tool curiosity.....
the “Loft Surface” tool seems a little too picky; see attached collage (SharkCAD Pro 1369)
Art
[email protected]
has anyone been able to confirm either or both of the situations shown?? if I have a setting wrong, it needs to get fixed pronto because not being able to do any surface work with the radiused rectangles is a serious pain!!
Art
[email protected]
:slight_smile: You’re right. Loft does not work correctly with a set of curves. Loft does not work with groups. Ruled surface works well with groups.
All the tools need auditing for :
1.) qualifying inputs
2.) useful tool rules & prompts
3.) constructive error messaging
One of the reasons Shark is hard to use is that the above are inconsistent
Skin surface does work… I don’t agree that Shark’s hard to use, in absolute or relative terms.
Yes, it’s easy to navigate once you know where the potholes are !
It would seem it is a pothole with the loft surface tool but this tool as far as have known it for years is supposed to work with surface edges and non-closed profiles especially since that command has the bulge aspect to it. I suppose you can bulge it to zero from the 1 setting. But to me production and less keystrokes is a factor so I rely on the ruled and skin surface commands.
When closed profiles, just use the ruled surface or skin surface that one works for both non-closed and open profiles as well on the diagonal round.
