Your problem: Dynamic Rotate is unusable the refresh rate drops to about 1 frame (I’m not exaggerating) regardless of the amount of movement
If you like to rotate it’s better to turn off the construction line (normally in construction layer), these lines are extreme long and ruins the dynamic rotation.
