It sure would be nice if it were possible to apply dimension constraints that actually can move an infinite plain.
I want to subdivide a hull in a way different from my usual method. Currently or usually, I cut the hull with infinite plans moved manually. But, these are not in sync with the constrained curves that set the positions of bulkheads.
I turned on Use Clip Planes and applied constraints to infinite plains and tried to change the distance, but the infinite plane seems programmed to not respond to dimension constraints.
I tried creating surfaces between curves, but, I ran into numerous “curves not planar”…
