Build 1622
Build 1622 for ViaCAD (Mac/Win), SharkCAD(Mac/Win), TurboCAD Mac are ready for testing.
Notable changes relative to 1621 include:
1622 Change Log
Up to 45X file read improvement for files with many ACIS curves such as sheets. (Measured 45 minutes now 5 minutes)
Improved file saves by optimizing copy portion by factor of 8 (Measured 40 seconds now 5 seconds)
Thin extrude was failing due to changes in ACIS
Correction for converting pressure angle in gear tool
Updated the Platinum metal color to correct Fresnel colors
Updated the closed body check in PowerPack mesh to solid to prevent invalid meshes from passing
Added caching of rgb color for significate speed improvement for all repaints containing faces
Updates to support rendered text, lines, dimensions using PhotoRendering
Added More logging to track down launch on crash issues with macOS Ventura
Disable auto save when user is changing layer names.
Updated build links:
ViaCAD 14 Windows: http://www.csi-concepts.com/Demo/viacad14/ViaCAD14_1622_WIP.exe
SharkCAD 14 Windows: http://www.csi-concepts.com/Demo/viacad14/SharkCAD14_1622_WIP.exe
Thanks,
Zunair
Deleted
