From Theo
How to draw a bracelet ![]()
Kind regards, Theo
You know that you always get the Dynamic Rotate tool in Stream when you press Alt and the right mouse button or the middle mouse button? You can also change the Dynamic Rotate midpoint in Stream while using another tool with Alt + right mouse button and Ctrl + click at the new midpoint. For snaps enabled, use the Measure tool or select the item before changing the midpoint. Sometimes, to fully exit the in-Stream Dynamic Rotate after changing the midpoint, you need to press Ctrl again to exit and enable changing the view with customized buttons again.
Hi MP,
Dynamic rotation with the Alt key and right mouse button I know.
I use it a lot to blend edges for example but in this case I didn’t had to use another tool while I was rotating.
Also with the microphone and recording on distracts me from some logical handlings…
However a good remark yours for everyone.
The rest I didn’t know, I will test your comment, thanks a lot!
MFG, Kind regards, Theo
