add another viewport
Hi
When making a model to sheet, how can I add another viewport from another part in the model? Is it possible to “re-select” the part of the model from an existing viewport frame?
Im using viacad V11 2d/3d
Thanks
Edit:
I actually found the “new draw view” option to create a second view in a sheet after using “model to sheet” I learned that you can copy paste selections from the model into the viewport. However not with polygons, lines and circles do but not polygons.
Polygons do go into the view if i do a new model to sheet.
has anyone an idea how I can add also polygons to a new view?
Everthing i do is in 2D.
regards.
I guess you have to change the polygons to single lines.
