V 15 ViaCad/Shark :: yes or no ?
What happens with sharkcad if Rosetta/Intel support stops? On a macbook the most runs on silicon processor. It looks at this moment it does not use the processor 100%. There are again some nasty bugs in V15. Extrude on a solid is not working any more. Large files are still slow. And radius, above 1500mm, the solid does not match the line. Some bugs are solved. I am concerned about the developments of the software.
1 user thanked SharkUser for this useful post.
The Windows version of version 15 performs better when handling large files with many objects in a single layer. Additionally, the "Linear Duplicate" function works faster. The new limit for objects in a layer appears to be 100,000. Up to this value, I can work smoothly and without delays.
3 users thanked MPSchmied for this useful post.
Me:
SharkCAD Pro v 12, Build 1592
(1,084kb) downloaded 20 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked ZeroLengthCurve for this useful post.
Thanks: 7 times Was thanked: 79 time(s) in 45 post(s)
NO since v14 bugs are not resolved and no native Apple Silicon and Metal support.
1 user thanked relaxibus for this useful post.
Thanks: 16 times Was thanked: 8 time(s) in 7 post(s)
Thank you for all your suggestions and criticism. I'm having a really hard time deciding whether to upgrade to version 15. I'll probably miss out on the discount price. It didn't work today. There should be a realistic upgrade price. Thank you all again for your thoughts. If my English is bad, complain to Google Translate :-)
1 user thanked a.wieneke for this useful post.
Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Any update on the bugs in sharkcad? The support seems to be offline, no response anymore. Are there any developments?
1 user thanked usershark2010 for this useful post.
Thanks: 267 times Was thanked: 82 time(s) in 48 post(s)
I was in contact with support about a license key about a month ago, and at that time, everything was working fine. I don’t know the current status.
BR Danny Win10 Pro, SharkCAD Pro v14(1653) v15(1722) Dell XPS 15 Sonoma 14.7.1 SharkCAD v14 Pro(1653), MacBook Pro 14 2023,M3
2 users thanked damhave for this useful post.
Originally Posted by: usershark2010 Any update on the bugs in sharkcad? The support seems to be offline, no response anymore. Are there any developments?
It's worrying, no news from Tim Olson for several months!!
2 users thanked Jean-Francois Jacques for this useful post.
Thanks: 29 times Was thanked: 14 time(s) in 4 post(s)
yes know what you mean ... i believe we need a seious blogger to showcase viacad ... i have tried a few of the others but viacad is fairly easy to use ... so if it was was shown on youtube by someone who has good followings maybe it would be looked after?? scruff007 sharkcad pro v15 windows and drives a jeep
2 users thanked scruff007 for this useful post.
Thanks: 631 times Was thanked: 103 time(s) in 65 post(s)
Thanks, what is your impression and insight on SharkCAD Pro v 15, any severe bugs and real problems yet unsolved ? what is the latest version number ? and when to expect a real final release ? Best regards ! G.
1 user thanked GARLIC for this useful post.
Thanks: 48 times Was thanked: 85 time(s) in 57 post(s)
Originally Posted by: Jean-Francois Jacques It's worrying, no news from Tim Olson for several months!!
"Currently working on V15 work in progress builds and V16." is Tim's current status.
I would expect he'll be updating the forum, when he has some more news. :)
Hope this helps
Mike
3 users thanked 24c for this useful post.
The current build is 1722. Upgrade in the menu shows V16, see attached image, but i don't think it means anything (it hangs when pressing the buy button).
v15 is in my opinion more stable than v14. I just split an imported 1M STL mesh with a plane but CPU load was only at approximately 16% on a 8945HS CPU, which is not very efficient use of a fast multi-core CPU.
Edited by user Friday, March 14, 2025 2:50:17 PM(UTC)
| Reason: spelling
damhave attached the following image(s):
(32kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
After launching SharkCAD 15, six instances of msedgewebview2.exe are automatically started. Each of these processes is launched with extremely long command lines. Interestingly, they can be manually terminated after startup—SharkCAD continues to function normally and does not attempt to restart the processes.
Question: How can these processes be permanently disabled?
I will attempt once again to completely remove Microsoft Edge from my system. However, this might fail, as Edge is deeply integrated into the operating system.
(109kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
may be this helps to get rid of "The Edge"...
https://www.solveyourtec...ndows-11-via-powershell/ Best regards
G.
2 users thanked GARLIC for this useful post.
Originally Posted by: GARLIC Your instructions didn’t work. I removed the contents of
Code: C:\Program Files (x86)\Microsoft
using
Unlocker .
Another untested option is:
Permanently uninstall Microsoft Edge – Guide on GIGA OS: Windows 10 | CPU: AMD Ryzen 7 2700 | RAM: 32 GB | Graphic: AMD Radeon RX 7900 XT | SharkFX9 Build 1162 | Unit: mm
