5 Pages«<2345>
#61 Posted : Friday, November 9, 2007 1:50:21 AM(UTC)
Matt - when you have a chance, could you confirm our STL fix is all in order.
Also, note the more efficient binary setting
The trouble with Cut3D and with Modela4 is that their focus appears to be to cut 'raster files'. Though Modela offers Contour cutting and Cut3D also offers other tricks like limiting the border to a halo around the object, their strategies are both quite limited
True z-level 'pocketing' and so on - as I understand - is much quicker .. which comes with more expensive software. My observation is that the better softwares get the head moving is cleverer ways .. for example sweeping up and down in the z axis when pocketing a compound form
Also learning strategies that cut less material are critical .. for example .. to cut only one edge of a pocket when that is all that's needed - therefor saving cut time and bit sharpness. I cant see how to do this in Cut3D
'Limiting surfaces' become important for blocking cuts that aren't necessary from a particular cut side - thus saving time. However, most cheap programs focus on importing and processing a single solid .. and don't allow limiting surfaces
I've been using CamWorks recently. It's a goddam awful interface and almost void of logic .. but provides for the most part quick cutting. It's expensive and I think there are better suites.
Rocket scientists definitely wrote that program. They have no concept of how designers work and are totally non graphical. Seems this is the case with many higher end packages as they too are aimed at machinists
It interfaces and works within SolidWorks .. which makes it quick to change stuff and reprocess those changes. The advantages TIM of a plug-in architecture !
tmay
#62 Posted : Saturday, November 10, 2007 3:37:45 PM(UTC)
tmay
Machining fillets with a ball endmill typically requires some sort of surfacing routine. Some CAM applications support a pencil mill routine that utilizes the fillet to create a path.
What I would be asking for in SharkFX (and I haven't a personal need for it, but i would use it if I had it) is to be able to synthesize a curve created by a ball rolling on the surface throughout the length of a constant fillet.
Basically, creating a path from an existing radial sweep.
If this is something that folks want, I can put it in the suggestions forum.
tom
mat
#63 Posted : Saturday, November 10, 2007 11:44:36 PM(UTC)
mat
hi jol ,
after ditching my prefs and re loading sp4 I have had a chance to try some stl exports to modela ( roland mdx 650 mill ) from what i can see - acis stl is working and is producing reduced file sizes , binary works and is smaller still but modela does not recognise it - i.e not a recognised file format - maybe i am missing something but i have tried a few options - iges files appear to be exporting consistanly and are reasonble size too - re cut 3d - I may look at it for the halo option alone as this would offer another approach beyond modela and for the money will mean i am cutting less air until i settle on some real tool pathing software - despite mayka's slow response ( enquiry emails ) what is your assesment of the software ???
#64 Posted : Sunday, November 11, 2007 11:53:49 AM(UTC)
Matt
No real response from Mayka here .. they are not answering questions
This makes me suspicious
Have you had a play with MeshCAM .. it's another cheapy one .. I'm not suggesting it's the answer .. but interesting to play with especially as the guy is really helpful
mat
#65 Posted : Sunday, November 11, 2007 4:53:08 PM(UTC)
mat
jol ,
no have not played with mesh cam , may give it a whirl . We might get a ex demo roland mdx 540 milling machine to go with the 650 we already have , the next trick will be to maximise output with the tool path generation and cutting strategies . while the roland machines are not the cheapest the reliability and useability makes it an easy option for our little studio . What sort of machines have you been on lately ???
nick
#66 Posted : Sunday, November 11, 2007 5:23:28 PM(UTC)
nick
I wouldn't read too much into slow response from the guys at Picasoft in France as I'm almost sure the issue is one of language. I would suggest you contact their representative here in the UK who is Patrick Thorn @ Patrick Thorn & Company he can be reached at the following URL:
http://www.patrick-thorn.co.uk
All the best
Nick
#67 Posted : Sunday, November 11, 2007 5:36:38 PM(UTC)
Matt .. just forwarded some Makya stuRf to you
This is MUCH more like it .. though I have no prices
cutting time comparable to CamWorks I'd suggest
probably a tenth for a complex part .. by not raster cutting
If anybody manages to find a price, pls let me know !
Presented well too !!
I'm testing an AXYZ machine .. (pronounced Axis) with CamWorks
Camworks is written really badly, is illogical, non graphical and confusing - I wouldn't recommend it, though offers piles of constant strategies. One I like in particular is 'constant stepover'. This gives you an x mm stepover on a compound curve as measured not in x, y or z but on the object surface (if that makes sense).
Am learning heaps about efficient cutting strategies
These apps are not written for people like us in general
mat
#68 Posted : Tuesday, November 13, 2007 2:14:50 PM(UTC)
mat
hi jol ,
thanks for the forward from mayka , one of the attachments is a retail price list but it is to small / low res to read - I am going to take nicks advice and put an inquiry to patrick thorn uk
#69 Posted : Tuesday, November 13, 2007 5:57:05 PM(UTC)
Oops .. didn't realise .. sorry Matt
Tried to zoom in .. also no go .. too small !
That's the first I've had back from anyone representing Mayka .. it's a start .. but I'd be hesitant about purchasing a product with that kind of response
That'd be like supporting a software package that keeps putting out the same bugs in successive releases .. that'd just be silly !
#70 Posted : Thursday, November 29, 2007 3:39:27 PM(UTC)
OK .. quick update
- SprutCAM from Russia believe it or not - is easy to use, nice interface .. quick results .. haven't milled anything from it yet - definately worth checking out !! Scallop height set allows something like 3D Constant Stepover for efficient milling of curvey surfs. YOu can also boundary limit your cut .. this is really what I want for my 2 sided cuts .. will report back when I get further
- Mayka is promising .. good support, but not from Mayka themselves, from an agent. They dont appear to have an English speaker handy. Haven't got into it properly yet .. but am hopeful. Tiered functionality .. so you're likely to pay a packet for a packet that will be useful. Appears to be user focused.
- Cut3D .. possibly a good next step on from Modela .. very cheap ! Absolutely worth a fiddle
- CamWorks .. bad SolidWorks integration, written by an engineer. Expensive, poor support .. good 3D constant stepover for curvy surfaces
#71 Posted : Thursday, December 6, 2007 11:48:39 AM(UTC)
.. and the winner of my research so far ..
definitely SprutCAM from Russia
Awesome bit of software .. fast, efficient, easy to use .. small code etc etc
Perfect English localisation
Does exactly !!! what it says on the box (ahem) .. no ifs or buts
So many times better than CamWorks .. it's just not funny !
Support is great .. sorry Mayka .. life's too short !
Price is not too horrible
ALBANO
#72 Posted : Tuesday, June 7, 2011 3:53:52 AM(UTC)
ALBANO
Was thanked: 28 time(s) in 15 post(s)
Tim,
There is a plugin that imports data directly from cobalt to SPRUTCAM? Any chance we can have such a plugin for Shark? Or is there any chance to use this plugin anyway?
ALBAN
#73 Posted : Tuesday, June 7, 2011 10:43:31 AM(UTC)
You don't need a plug-in. It takes igs files. What's more, the toolpaths it makes are not based upon faceting the data. Toolpaths are formed upon the nurbs surfaces directly (as I understand)
ALBANO
#74 Posted : Wednesday, June 8, 2011 6:36:00 AM(UTC)
ALBANO
Yes, I know but Iges i find quite unreliable sometimes....
What kind of IGES do you use?
Btw. SPRUTCAM doesnt tesselate the object before generating the toolpath-> very good for smooth NC-paths...
#75 Posted : Wednesday, June 8, 2011 9:19:03 AM(UTC)
On the odd occasion I have problems with (standard set) iges, I take a sat 12 file over to another program (like Solidworks) and spit out a standard set iges from there.
You have an option to turn the surfaces to facets and throw toolpaths over them that way - but I only used it once or twice
Sprut is very good indeed - but it's not cheap (I think it was 3K here in the UK) - and the support guy was not the most patient with us - so we haven't upgraded from v2007.
Have you managed to get a better price ? I'd expect the price has come down somewhat now !? Perhaps you can even buy it direct from Russia, I don't know
ALBANO
#76 Posted : Wednesday, June 8, 2011 4:29:36 PM(UTC)
ALBANO
we had Sprutcam until 2 Years ago. Than changed to VX. Thats a full CAD-CAM Package but everything is too complicated and constrained. Now I have heard that Sprutcam has 5axis support from now on we think of going back to sprutcam. Only problem always was Import IGES files...
The Price is not coming down. :( Only for older versions. I Think they still sell the v2007.. its around 2000 here in Germany Full version goes up to 8000 :eek:
#77 Posted : Wednesday, June 8, 2011 4:45:09 PM(UTC)
Aha - ok ... that is expensive. What kind of 5 axis work are you doing ? Jol
ALBANO
#78 Posted : Thursday, June 9, 2011 12:19:05 AM(UTC)
ALBANO
We have an ABB 6650 Robot with a spindle at the flange and 2 self built smaller milling machines. We make original moulds for bigger things like Cars and entertainment cabins. We are not so exactly as big milling machines but we can be much cheaper :)
#79 Posted : Thursday, June 9, 2011 1:44:17 AM(UTC)
tooling for rotomolding ?
ALBANO
#80 Posted : Thursday, June 9, 2011 1:22:04 PM(UTC)
ALBANO
No. For fibre reinforced parts in the moment. What kind of temperatures do rotomolding moulds require? We can go 150-200C with relatively cheap fibre reinforced moulds....
Guest (28)
5 Pages«<2345>
