2 Pages12>
#1 Posted : Thursday, April 18, 2024 3:49:33 PM(UTC)
We've updated the V14 builds for ViaCAD, SharkCAD, and TurboCAD Mac to build 1654.
These builds can be downloaded at :
http://www.masterviacad.com/beta/beta.php
Build 1654 Change Log
--Issue printing to PDF and blurry or double lines
--Crash correction on some machines regarding unknown file types
--Crash correction for exploding very large assemblies
--Correction with clash analysis tool and results
I'm also adding a few more beta users to test V15. Currently it is the TurboCAD Mac brand which supports reading/writing ViaCAD and Shark files.
If you are interested please send me an email at Tim.olson AT encore.com. You must be a current user of V14.
V15 has a collection of enhancements plus the addition of Copilot which allows you to talk to documents or talk to your cad data.
For a video of Copilot see the link below:
CoPilot
https://youtu.be/9bknwOHL5-I
thanks 3 users thanked Tim Olson for this useful post.
bbuxton on 4/19/2024(UTC), GARLIC on 5/18/2024(UTC), scruff007 on 9/21/2024(UTC)
Claus2
#2 Posted : Saturday, April 20, 2024 8:25:27 AM(UTC)
Claus2
Was thanked: 29 time(s) in 16 post(s)
Eyedropper tool is not working here...
thanks 2 users thanked Claus2 for this useful post.
damhave on 4/20/2024(UTC), GARLIC on 4/20/2024(UTC)
Elektroniker
#3 Posted : Sunday, April 21, 2024 1:14:34 AM(UTC)
Elektroniker
When I load some files that were created with the previous version (1653), Viacad crashes.
Only a file which contains a simple sketch (2D) is loading.
Wolfgang
Edited by user Sunday, April 21, 2024 1:15:09 AM(UTC)  | Reason: Not specified
thanks 1 user thanked Elektroniker for this useful post.
damhave on 4/29/2024(UTC)
curtk
#4 Posted : Monday, April 29, 2024 9:46:52 AM(UTC)
curtk
Was thanked: 32 time(s) in 21 post(s)
will there be a fix for the undo feature or is this even a known problem ? When I hit undo I often lose most of my solids in this version 14
thanks 2 users thanked curtk for this useful post.
damhave on 4/29/2024(UTC), jlm on 4/30/2024(UTC)
relaxibus
#5 Posted : Monday, May 6, 2024 6:45:43 AM(UTC)
relaxibus
Undo has been allways a time bomb. You never know what happens. But.. we talk about v15 with AI... Cool...
curtk
#6 Posted : Wednesday, May 8, 2024 8:48:03 AM(UTC)
curtk
The old old versions were bad for it but that seemed resolved for at least few of the versions . I don't want to disrespect the work that goes into a software like this but I fail to see why I keep upgrading only to find myself using an old version (v8) ?
thanks 1 user thanked curtk for this useful post.
memphisjed on 6/5/2024(UTC)
creativecad
#7 Posted : Monday, May 13, 2024 7:10:04 PM(UTC)
creativecad
I am using WIP 1641 mostly. It works about the best I've seen ViaCad pro work which is pretty awesome. Every once in a while it will freeze up or something, but mostly it has been nice. If I do have trouble with a particular file, I will switch to the latest WIP which usually resolves my issue.
The latest WIP has an issue where you cannot always click and drag objects around. I've gotten used to the click and drag which works in the 1641 WIP.
I don't do any surface or mesh modeling. Just solid modeling and 2d. So I can't speak for everything in the program, but I am happy with ViaCad. I continue to find tricks to make drawing faster and better.
Of course, there are many improvements that ViaCad could implement, and a few lingering bugs I work around okay, but there are also many nice features in ViaCad that I have not seen in any other cad programs.
Well, I am happy. No more damaged files or constant crashes. My work is getting done, and it's mostly fast.
ViaCad 10 Pro
ViaCad 9
Windows 10
thanks 1 user thanked creativecad for this useful post.
specktech on 11/22/2024(UTC)
TruggyDriver69
#8 Posted : Wednesday, May 15, 2024 11:08:22 AM(UTC)
TruggyDriver69
Countersink not working at all on 1654.
24c
#9 Posted : Wednesday, May 15, 2024 1:07:47 PM(UTC)
24c
Was thanked: 71 time(s) in 52 post(s)
Are you sure? Is it not the default values clashing, here's a through hole with countersunk...and sizes
Modify > Solid Feature > Hole Feature
Mike
Edited by user Wednesday, May 15, 2024 1:11:02 PM(UTC)  | Reason: Grammar
macOS Tahoe - v16 beta
gierosek
#10 Posted : Wednesday, May 15, 2024 1:53:58 PM(UTC)
gierosek
Hello, I am thinking about buying sharkcad.
Can you tell me if there is any manual way to unfold the element flat?
I know that the program does not have an unbend option, and the unfold option does not work on solids.
I would like to make layouts for the burner.
#11 Posted : Thursday, May 16, 2024 4:43:01 AM(UTC)
Was thanked: 182 time(s) in 110 post(s)
Hello Gierosek,
We can unbend ... only what we have bent before, using history in entities explorer...
It's easy to unfold simple solids after converting to surfaces, and re-build flat volumes from the surfaces.
We need more information about what kind of solid you want to unfold...
Edited by user Friday, May 17, 2024 3:23:09 AM(UTC)  | Reason: Not specified
gierosek
#12 Posted : Thursday, May 16, 2024 8:07:49 AM(UTC)
gierosek
For example, the design of an excavator bucket. The bottom is bent on a press brake several or a dozen times to obtain the appropriate shape.
I know the bending radius of the sheet metal for my machine, I need to flatten the bottom and mark the bending places.
This is one of my works.
Now I have finished the trial versions of viacad pro. Are my surgeries sufficient viacad pro or is it better to buy sharkcad pro?
TruggyDriver69
#13 Posted : Saturday, May 18, 2024 5:17:13 AM(UTC)
TruggyDriver69
Mike
Positive it’s not working. All settings are correct in the fields. I rolled back the another version of Viacad 14 and it works perfectly on this version.
gierosek
#14 Posted : Saturday, May 18, 2024 11:49:47 AM(UTC)
gierosek
Hello.
I tested a bit and you can unbend the solids in history, but you can't unbend them to 0 degrees. Minimum 0.001st.
The second issue is the problem with parametricity - when you try to change the angles, the solid falls apart. (Model parametr error)
The only way is to undo the bending in history.
But what if we want to change the angle and the block falls apart?
Link to photos
https://files.fm/u/5rm8dzvrcv
Edited by user Saturday, May 18, 2024 11:53:57 AM(UTC)  | Reason: Not specified
thanks 1 user thanked gierosek for this useful post.
#15 Posted : Sunday, May 19, 2024 8:23:54 AM(UTC)
Was thanked: 202 time(s) in 140 post(s)
And you don't need a K-factor? It's pointless to try the bending function in SharkViacad at all. Your files are being blocked by my antivirus program. BricsCAD has a sheet metal unfolding function. SharkCAD Pro also does not offer usable options for sheet metal unfolding.
Edited by user Sunday, May 19, 2024 8:26:38 AM(UTC)  | Reason: Not specified
GARLIC on 5/19/2024(UTC), damhave on 5/20/2024(UTC)
gierosek
#16 Posted : Monday, May 20, 2024 4:09:38 AM(UTC)
gierosek
I don't need k-factor, i have a bend calculator.
I will add that I make buckets for excavators and millimeter accuracy is not required.
This program is good because of its simple operation, , but I decided to test TurboCad for Windows…
24c
#17 Posted : Wednesday, May 22, 2024 2:23:49 AM(UTC)
24c
I've only tested this on macOS, but I had no issues, and I did edit in the Inspector as well to double check, but sorry all worked for me.
Mike
#18 Posted : Wednesday, September 18, 2024 8:49:21 PM(UTC)
Bugy, bugy, bugy
1654 printing by layer doesn't work on mack,
I return to 1653 (printing rendering its works on this build), but it crash every time I quit the program, no matter what, often I quick the app to refresh since start to do som glitchy things, (like no render lines, or blinking menus make them unselectables), and every time I quit the app, i got a crash message
Here the crash log
Translated Report (Full Report Below)
Process: SharkCAD 14 [3932]
Path: /Applications/SharkCAD 14.app/Contents/MacOS/SharkCAD 14
Identifier: com.encore.shark14esd
Version: 14.1.0 (1653)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 502
Date/Time: 2024-09-18 19:48:13.6739 -0700
OS Version: macOS 13.6.4 (22G513)
Report Version: 12
Bridge OS Version: 8.3 (21P3049)
Anonymous UUID: 9253D51A-7FC4-5722-3A3D-BFF26A87211D
Sleep/Wake UUID: 7275A17E-A603-4706-AFCE-6280B1D3ECEC
Time Awake Since Boot: 17000 seconds
Time Since Wake: 5717 seconds
System Integrity Protection: disabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 6 Abort trap: 6
Terminating Process: SharkCAD 14 [3932]
Application Specific Information:
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x7ff812513196 __pthread_kill + 10
1 libsystem_pthread.dylib 0x7ff81254aee6 pthread_kill + 263
2 libsystem_c.dylib 0x7ff812471b45 abort + 123
3 libc++abi.dylib 0x7ff812505282 abort_message + 241
4 libc++abi.dylib 0x7ff812504cb2 __cxa_pure_virtual + 18
5 SharkCAD 14 0x10e8b245c 0x10b790000 + 51520604
6 SharkCAD 14 0x10e8b2180 0x10b790000 + 51519872
7 SharkCAD 14 0x10bb0a345 0x10b790000 + 3646277
8 libsystem_c.dylib 0x7ff81241cba1 __cxa_finalize_ranges + 409
9 libsystem_c.dylib 0x7ff81241c9bb exit + 35
10 AppKit 0x7ff815933a5f -[NSApplication terminate:] + 1724
11 SharkCAD 14 0x10bbef91c 0x10b790000 + 4585756
12 CoreFoundation 0x7ff81261c688 __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 137
13 CoreFoundation 0x7ff8126b53fe ___CFXRegistrationPost_block_invoke + 88
14 CoreFoundation 0x7ff8126b5353 _CFXRegistrati
MacOSX Sonoma 14.7.1
thanks 1 user thanked lgrijalva for this useful post.
damhave on 9/19/2024(UTC)
memphisjed
#19 Posted : Sunday, October 27, 2024 8:45:09 PM(UTC)
memphisjed
Was thanked: 12 time(s) in 10 post(s)
I can not use this build at all. crashes after anything more than drawing a 2d rectangle. crash on opening any file.
windows 11
i7
32 g ram
amd pro graphics
My build 1651 vanished, back to 1635. 51 was best of v14.
thanks 2 users thanked memphisjed for this useful post.
damhave on 10/28/2024(UTC), lgrijalva on 12/24/2024(UTC)
#20 Posted : Tuesday, December 24, 2024 3:23:07 PM(UTC)
I must say that SharCad pro V14 builds 1645, 1653, and 1654 are unusable on macOS Sonoma, lot of crashes, render lines vanished ( they just disappear from the screen), damaged files, jumping screen (a lot)
What happened to this so great software that I used to love and recommend??
Guest (9)
2 Pages12>
