ViaCAD/SharkCAD/TurboCAD Mac 1654
We've updated the V14 builds for ViaCAD, SharkCAD, and TurboCAD Mac to build 1654.
These builds can be downloaded at :
http://www.masterviacad.com/beta/beta.php Build 1654 Change Log --Issue printing to PDF and blurry or double lines
--Crash correction on some machines regarding unknown file types
--Crash correction for exploding very large assemblies
--Correction with clash analysis tool and results
I'm also adding a few more beta users to test V15. Currently it is the TurboCAD Mac brand which supports reading/writing ViaCAD and Shark files.
If you are interested please send me an email at Tim.olson AT encore.com. You must be a current user of V14.
V15 has a collection of enhancements plus the addition of Copilot which allows you to talk to documents or talk to your cad data.
For a video of Copilot see the link below:
CoPilot https://youtu.be/9bknwOHL5-I Thanks
3 users thanked Tim Olson for this useful post.
Thanks: 8 times Was thanked: 29 time(s) in 16 post(s)
Eyedropper tool is not working here...
2 users thanked Claus2 for this useful post.
Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
When I load some files that were created with the previous version (1653), Viacad crashes.
Only a file which contains a simple sketch (2D) is loading.
Wolfgang
Edited by user Sunday, April 21, 2024 1:15:09 AM(UTC)
1 user thanked Elektroniker for this useful post.
Was thanked: 32 time(s) in 21 post(s)
will there be a fix for the undo feature or is this even a known problem ? When I hit undo I often lose most of my solids in this version 14
2 users thanked curtk for this useful post.
Thanks: 7 times Was thanked: 79 time(s) in 45 post(s)
Undo has been allways a time bomb. You never know what happens. But.. we talk about v15 with AI... Cool...
The old old versions were bad for it but that seemed resolved for at least few of the versions . I don't want to disrespect the work that goes into a software like this but I fail to see why I keep upgrading only to find myself using an old version (v8) ?
1 user thanked curtk for this useful post.
Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
I am using WIP 1641 mostly. It works about the best I've seen ViaCad pro work which is pretty awesome. Every once in a while it will freeze up or something, but mostly it has been nice. If I do have trouble with a particular file, I will switch to the latest WIP which usually resolves my issue. The latest WIP has an issue where you cannot always click and drag objects around. I've gotten used to the click and drag which works in the 1641 WIP. I don't do any surface or mesh modeling. Just solid modeling and 2d. So I can't speak for everything in the program, but I am happy with ViaCad. I continue to find tricks to make drawing faster and better. Of course, there are many improvements that ViaCad could implement, and a few lingering bugs I work around okay, but there are also many nice features in ViaCad that I have not seen in any other cad programs. Well, I am happy. No more damaged files or constant crashes. My work is getting done, and it's mostly fast.
ViaCad 10 Pro ViaCad 9 Windows 10
1 user thanked creativecad for this useful post.
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Countersink not working at all on 1654.
Thanks: 48 times Was thanked: 85 time(s) in 57 post(s)
Originally Posted by: TruggyDriver69 Countersink not working at all on 1654.
Are you sure? Is it not the default values clashing, here's a through hole with countersunk...and sizes
Modify > Solid Feature > Hole Feature
Mike
Edited by user Wednesday, May 15, 2024 1:11:02 PM(UTC)
| Reason: Grammar
(320kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Hello, I am thinking about buying sharkcad. Can you tell me if there is any manual way to unfold the element flat? I know that the program does not have an unbend option, and the unfold option does not work on solids. I would like to make layouts for the burner.
Originally Posted by: gierosek Hello, I am thinking about buying sharkcad. Can you tell me if there is any manual way to unfold the element flat? I know that the program does not have an unbend option, and the unfold option does not work on solids. I would like to make layouts for the burner.
Hello Gierosek,
We can unbend ... only what we have bent before, using history in entities explorer...
It's easy to unfold simple solids after converting to surfaces, and re-build flat volumes from the surfaces.
We need more information about what kind of solid you want to unfold...
Edited by user Friday, May 17, 2024 3:23:09 AM(UTC)
For example, the design of an excavator bucket. The bottom is bent on a press brake several or a dozen times to obtain the appropriate shape. I know the bending radius of the sheet metal for my machine, I need to flatten the bottom and mark the bending places. This is one of my works. Now I have finished the trial versions of viacad pro. Are my surgeries sufficient viacad pro or is it better to buy sharkcad pro?
Originally Posted by: 24c Originally Posted by: TruggyDriver69 Countersink not working at all on 1654.
Mike
Positive it’s not working. All settings are correct in the fields. I rolled back the another version of Viacad 14 and it works perfectly on this version.
Hello.
I tested a bit and you can unbend the solids in history, but you can't unbend them to 0 degrees. Minimum 0.001st.
The second issue is the problem with parametricity - when you try to change the angles, the solid falls apart. (Model parametr error)
The only way is to undo the bending in history.
But what if we want to change the angle and the block falls apart?
Link to photos
https://files.fm/u/5rm8dzvrcv Edited by user Saturday, May 18, 2024 11:53:57 AM(UTC)
1 user thanked gierosek for this useful post.
Originally Posted by: gierosek The only way is to undo the bending in history.
And you don't need a K-factor? It's pointless to try the bending function in SharkViacad at all. Your files are being blocked by my antivirus program. BricsCAD has a sheet metal unfolding function. SharkCAD Pro also does not offer usable options for sheet metal unfolding.
Edited by user Sunday, May 19, 2024 8:26:38 AM(UTC)
2 users thanked MPSchmied for this useful post.
I don't need k-factor, i have a bend calculator. I will add that I make buckets for excavators and millimeter accuracy is not required. This program is good because of its simple operation, , but I decided to test TurboCad for Windows…
Originally Posted by: TruggyDriver69 Positive it’s not working. All settings are correct in the fields. I rolled back the another version of Viacad 14 and it works perfectly on this version.
I've only tested this on macOS, but I had no issues, and I did edit in the Inspector as well to double check, but sorry all worked for me.
Mike
Thanks: 39 times Was thanked: 30 time(s) in 23 post(s)
Bugy, bugy, bugy 1654 printing by layer doesn't work on mack, I return to 1653 (printing rendering its works on this build), but it crash every time I quit the program, no matter what, often I quick the app to refresh since start to do som glitchy things, (like no render lines, or blinking menus make them unselectables), and every time I quit the app, i got a crash message Here the crash log Translated Report (Full Report Below)
Process: SharkCAD 14 [3932] Path: /Applications/SharkCAD 14.app/Contents/MacOS/SharkCAD 14 Identifier: com.encore.shark14esd Version: 14.1.0 (1653) Code Type: X86-64 (Native) Parent Process: launchd [1] User ID: 502 Date/Time: 2024-09-18 19:48:13.6739 -0700 OS Version: macOS 13.6.4 (22G513) Report Version: 12 Bridge OS Version: 8.3 (21P3049) Anonymous UUID: 9253D51A-7FC4-5722-3A3D-BFF26A87211D Sleep/Wake UUID: 7275A17E-A603-4706-AFCE-6280B1D3ECEC Time Awake Since Boot: 17000 seconds Time Since Wake: 5717 seconds System Integrity Protection: disabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Termination Reason: Namespace SIGNAL, Code 6 Abort trap: 6 Terminating Process: SharkCAD 14 [3932] Application Specific Information: abort() called Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 libsystem_kernel.dylib 0x7ff812513196 __pthread_kill + 10 1 libsystem_pthread.dylib 0x7ff81254aee6 pthread_kill + 263 2 libsystem_c.dylib 0x7ff812471b45 abort + 123 3 libc++abi.dylib 0x7ff812505282 abort_message + 241 4 libc++abi.dylib 0x7ff812504cb2 __cxa_pure_virtual + 18 5 SharkCAD 14 0x10e8b245c 0x10b790000 + 51520604 6 SharkCAD 14 0x10e8b2180 0x10b790000 + 51519872 7 SharkCAD 14 0x10bb0a345 0x10b790000 + 3646277 8 libsystem_c.dylib 0x7ff81241cba1 __cxa_finalize_ranges + 409 9 libsystem_c.dylib 0x7ff81241c9bb exit + 35 10 AppKit 0x7ff815933a5f -[NSApplication terminate:] + 1724 11 SharkCAD 14 0x10bbef91c 0x10b790000 + 4585756 12 CoreFoundation 0x7ff81261c688 __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 137 13 CoreFoundation 0x7ff8126b53fe ___CFXRegistrationPost_block_invoke + 88 14 CoreFoundation 0x7ff8126b5353 _CFXRegistrati
1 user thanked lgrijalva for this useful post.
Thanks: 35 times Was thanked: 15 time(s) in 13 post(s)
I can not use this build at all. crashes after anything more than drawing a 2d rectangle. crash on opening any file. windows 11 i7 32 g ram amd pro graphics My build 1651 vanished, back to 1635. 51 was best of v14.
2 users thanked memphisjed for this useful post.
I must say that SharCad pro V14 builds 1645, 1653, and 1654 are unusable on macOS Sonoma, lot of crashes, render lines vanished ( they just disappear from the screen), damaged files, jumping screen (a lot) What happened to this so great software that I used to love and recommend?? Luis G
