Ignore me, I'm wrong! The behaviour is different depending on context.
Edited by user Tuesday, January 9, 2018 4:20:28 PM(UTC)
I tried changing the arc to a beizer curve, and a variety of other things, I got a loop da loop from one of them, and large wobbly rads, and then a small wobbly rad. I then put a line almost tangential to the arc and used the too, that was equally as bad.
Thanks: 31 times Was thanked: 27 time(s) in 12 post(s)
Originally Posted by: UGMENTALCASE Should I be joining curve or grouping curves? As far as I'm concerned I'd be joining them, otherwise we need a work around manual! NeuTechFLA, when you flatten drawing views do they move? Seems Sharks functions which are the same as ViaCADs have issues as well.
I have not had to (or better yet have chosen not to) flatten a view(s). Maybe this is resistance trauma from my very Old School days with I/EMS that used flattened views too. Great out of the gate the first time....but painful later on when changing things. Shark seems to be pretty stable and robust with the MTS so far. One of the reasons I purchased Shark Pro was the GD&T, which seems pretty good from the limited times I have used it. There are some quirks with placement but I need more time in the saddle with it to know it inside out.
However, when I get a moment today, I will flatten some views and try to "break" it. Report to follow.
EDIT: Why would you want or need to flatten a view if it's not required in order to create a drawing?
Edited by user Wednesday, January 10, 2018 6:46:52 AM(UTC)
Flatten will simplify - if you don't need the link to higher parentage geometry, dump it !
I too used EMS - all I can say is thank fuck those days are gone !
Rest in hell EMS!
Tim has done a truly amazing thing here - not in providing a perfect system (it doesn't exist anyway) ... but in providing a stable system that is both usable and affordable !!
Edited by user Wednesday, January 10, 2018 7:44:21 AM(UTC)
Jolyon attached the following image(s):
(24kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
It was when I was playing around with it. I added, into the views, a symbol. And depending on what axis plane it was developed on, depends on whether you see it in the view. So i flattened the view to test that out and it moved, but I could inded use my symbols properly
Jolyon, I remember those old dual monitor stations as Intergraph MicroStation pre-1989. I was never on those stations. I started with Rev 1.4 of I/EMS in mid '89 to late '92 at rev 3.2? It was a single monitor configuration and I have only been able to find one, very small, grainy image of the GUI. I am not sure we ran the same unless the I/EMS I ran was also available on the dual station.
Edited by user Wednesday, January 10, 2018 12:34:11 PM(UTC)
(23kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
UGMENTALCASE, I see the same, minute shift when flattening as well. It's slight, but there. While it should not be occurring, I guess I suggest not flattening unless you have to do so. And then, simply resolve that if some changes you will have the manually fix things. Not the best deal in the World.
Which view do you see moving when flattening? What geometry moves the view geometry or objects that were added or both?
What is the scale of the view. I tried a simple drawing but the geometry 1:1 inside the draw view did not move when flattened.
Edited by user Wednesday, January 10, 2018 1:57:54 PM(UTC)
jdi000, I want to correct my earlier post to UGMENTALCASE. I just did MTS on an "assembly" and I notice two things. Upon first placement, the orthogonal views are not aligned with one another see the image below. Once they are explicitly aligned all seems fine. Then upon flattening I notice what appears to be slight movement. I believe it is the 3D geometry getting replaced with the 2D entities, which I assume have "tolerance/line weight/precision" that may be less precise than the 3D? this may be what is perceived as movement. When zoomed in quite close, the orthogonal projections still seem aligned. This is on my system and preferences. It may be different for others.
Also, I see actual view movement whenever a view's boundary is changed/cropped. Explicit alignment is then required again to get it all correct. Maybe this is by design?
(336kb) downloaded 16 time(s). You cannot view/download attachments. Try to login or register.
Morning all,
I've recreated it, it's when flattening a section view. Attached is a screen recording of it. And yes you get the same result if I flattened the origin view first
flatten origin view first.mp4
(3,195kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
another video
flatten origin view first.zip
(2,559kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
