Originally Posted by: jdi000
Shawn
I am not trying to be smart here, but I don't see these print issues with line weights in windows.
Will check. Doing some trial and error settings now with layout setup, PDF setup, page setup, display setup, draw setup. Was there one I missed?
It'd be nice if ViaCAD Pro 6 B831 defaulted to something usable. So far, one trick is to go to Page Layout while the drawing is first fresh on the screen to make sure that it fits the page size properly. Without doing that, all bets are off of getting any quality from printing. Now trying the three different pen weights to see any difference. Turning weights off makes drawing on an "ARCH C" size page tolerable.
Ok. ViaCAD (Pro)'s Model to Sheet display is simply the Page Layout thumbnail preview blown up to full screen size. The (OpenGL?) preview drawing language and the PDF drawing language are not the same accuracy when you zoom in. Even using a different PDF generator seems to treat ViaCAD's drawing with slight differences.
If ViaCAD 2D/3D can print at least as good as ViaCAD Pro, I'd say that is pretty good still for the money paid (under $99?) to do ARCH C/D/E page printing.
By the way, I'm using Adobe Acrobat 5's PDF and PDF995 to make PDF's. Acrobat 5 does only letter and legal size paper while PDF995 does everything else. I have not tried CutePDF. I hear it does ARCH C/D/E sizes, too.
I included a PDF from ViaCAD Pro 6 B831 using PDF995. It looks fine with Acrobat Reader 9.0.0.
ViaCAD_Pro_housing.pdf
(462kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
