3 Pages123>
wdp67
#1 Posted : Saturday, September 5, 2009 7:16:52 PM(UTC)
wdp67
Was thanked: 5 time(s) in 5 post(s)
Could someone please help me with drawing a solid that looks like a bolt, I tried following the example on the forum but cant figure it out.
Walt
ttrw
#2 Posted : Sunday, September 6, 2009 4:11:35 AM(UTC)
ttrw
Hi Walt.
Take a look at this post, please come back if you get into trouble :)
best,
Tom Fenn
http://forum.punchcad.com/showt...?t=914&highlight=helical
ttrw
#3 Posted : Sunday, September 6, 2009 4:16:04 AM(UTC)
ttrw
actually, reading back on this tutorial, I've learnt so much more, and so more could be added- like actually making the bolt part, and then adding the two together using booleans. And of course, using the 'C' key!
wdp67
#4 Posted : Sunday, September 6, 2009 9:04:26 AM(UTC)
wdp67
Sorry to be so dumb, but that was what I was following, and I still could not get it to work.
Walt
wdp67
#5 Posted : Sunday, September 6, 2009 4:10:16 PM(UTC)
wdp67
Anyone? Please!
zumer
#6 Posted : Sunday, September 6, 2009 5:51:13 PM(UTC)
zumer
I'm assuming that it's the thread that's the sticking point, shoulder and head being simple primitives. I've laid out 50mm of 6mm diameter thread. I drew a line as base axis and used the axis to place 50mm of 6mm diameter, 1mm pitch helix. The red profile is ISO metric, with 60 degrees included angle, pitch/4 for the outer fillet, pitch/8 for the inner. The profile is closed, so hit the solid single rail sweep tool, select the profile and use the helix as the sweep path. The cylinders will fill the hollow centre and fill out the shoulder, the head is an extrusion of a hex profile.
bolt thread.vc3 (55kb) downloaded 6 time(s).
wdp67
#7 Posted : Sunday, September 6, 2009 6:15:03 PM(UTC)
wdp67
Ok I am still doing something wrong. I am not sure what I should have in the drop down boxes that are at the top(sweep perp,sweep in place,sweepright) and (curve extents, between points, to object).
When I tried following your post I did get half of a thread showing, but it was the size of the large part of the bolt. I just am not following along very well. Also I am asked to pick start and end, and do not know what to pick for that either.
Walt
NickB
#8 Posted : Sunday, September 6, 2009 6:26:06 PM(UTC)
NickB
Use these settings:
One Rail Swwep Solid
Sweep In Place
Curve Extents
Twist Angle = 0
Darft Angle = 0
Shark FX 9 build 1143
OS X 9.5
matter.cc
wdp67
#9 Posted : Sunday, September 6, 2009 6:38:19 PM(UTC)
wdp67
Ok I trie that, though I do not aget a twist angle or draft angle box. When I follow what you just said, I get 1/2 a thread showing, missing the back half?
Walt
wdp67
#10 Posted : Sunday, September 6, 2009 6:45:26 PM(UTC)
wdp67
Ok I just continued with another sweep and I pick the red contour going the other way and I have the back half showing now but there is empty space at the top of the thread?
wdp67
#11 Posted : Sunday, September 6, 2009 6:47:59 PM(UTC)
wdp67
here is a pic
wdp67 attached the following image(s):
wdp67
#12 Posted : Sunday, September 6, 2009 6:49:45 PM(UTC)
wdp67
Ultimatly I guess I need a step by step on how to do all this. I need to learn how to figure out what I need to draw and sweerp to get the various threads that I want to draw. IE 1/4-20, 10-32 etc.
zumer
#13 Posted : Sunday, September 6, 2009 7:47:18 PM(UTC)
zumer
You have two one rail sweep tools, one for surface (green icons) and one for solid (blue icons). Solids need closed profiles to sweep. You need to pull a selection window around all of the lines and curves that I've drawn that enclose the thread profile, or hold shift while you select them individually to close the profile, otherwise solid sweep will throw an error message. You've swept a surface, not a solid.
I've used an ISO metric thread for the drawing, ISO threads are defined by pitch, which is the lead (coaxial linear travel) of the bolt per revolution. Imperial threads use threads/inch, so you have to work out the pitch by dividing an inch by the number of threads. They also use a few different methods to define diameter. 1/8, 1/4 etc gives you the diameter directly, 10-32 gives you a wire gauge that you'll have to find a diameter for. You'll need to calculate those figures to define a helix to sweep, and although I don't know definitively, I believe imperials also have a variety of thread forms. ISOs are generally standard, 60 included angle, pitch/8 fillet inner, pitch/4 outer fillet.
wdp67
#14 Posted : Sunday, September 6, 2009 8:03:22 PM(UTC)
wdp67
I may have got it, thanks to all your help!! Have a look at this picture. Also lease check the drawing and tell me if I am getting it!!
Walt
Ok Burst my bubble I did the file with sweep Surface, I just found the sweep solid button, but when I try that I get an error
.250-20 screw.vc3 (124kb) downloaded 5 time(s).
.250-20 screw.jpg (22kb) downloaded 5 time(s).
zumer
#15 Posted : Sunday, September 6, 2009 8:22:09 PM(UTC)
zumer
Probably just indicating that you haven't selected all the segments that enclose the profile. Change the segments to another colour so they show up red when you select them. Hold shift while you select them, release it when you've got them all. You're almost there.....
wdp67
#16 Posted : Sunday, September 6, 2009 8:29:32 PM(UTC)
wdp67
Ok I think I got it, check it out please and let me know! I am not sure I understand about the fillets though.
Walt
.250-20 screw.vc3 (190kb) downloaded 5 time(s).
zumer
#17 Posted : Sunday, September 6, 2009 8:36:39 PM(UTC)
zumer
The fillets on the profile are for clearance, in the real world they're used to ensure that the nut and bolt will screw together without binding. I got them back to front. It should be smaller on the valley of the thread, larger on the thread nose, of course, so they don't interfere. You're almost there, just use a smaller diameter inner cylinder that just fills the cavity without smothering the thread form.
Just had another look at your file, you've swept surfaces again for the flanks of the thread. You've drawn the triangular profile right, just hold shift while you select the three segments to sweep them as a solid.
wdp67
#18 Posted : Sunday, September 6, 2009 8:52:37 PM(UTC)
wdp67
I am close, I think where I am messing up is the drawing of the part to sweep. how did fillet it so that it came out right. see attached drawing.
The pitch of a 1/4-20 is .05.
Walt
.25-20 profile.vc3 (7kb) downloaded 5 time(s).
zumer
#19 Posted : Sunday, September 6, 2009 9:23:41 PM(UTC)
zumer
Your thread profile isn't an equilateral triangle, so I've overlaid symmetrical flanks. I've used imperial units, and drawn an axis, and a helix of .05" pitch. You'll see how the helix relates to the intersection of the flank profile, you need to locate the profile correctly before you fillet for it to follow the sweep path relative to that point.
.25-20 profile.vc3 (21kb) downloaded 5 time(s).
wdp67
#20 Posted : Sunday, September 6, 2009 9:54:00 PM(UTC)
wdp67
Like this?
this.vc3 (21kb) downloaded 5 time(s).
Guest (14)
3 Pages123>
