2 Pages<12
awieneke
#21 Posted : Sunday, October 12, 2008 2:38:28 AM(UTC)
awieneke
to all with your fast and helpfully replies.
I started to rebuild my ring with ViaCadPro, bending along spline ( great tool ) and mirror.
Now it workes. I do not know why.
I tried to change the resolution and the color.
I tried the file from Steve. i had no chance. So i rebuilt it in a different way ( only one booling operations ) and it works.
if you like you can see one of the results in the attachement.:)
awieneke attached the following image(s):
#22 Posted : Sunday, October 12, 2008 4:11:21 AM(UTC)
Brilliant result Andreas !
How did you make the stones ?
JL
awieneke
#23 Posted : Sunday, October 12, 2008 4:23:25 AM(UTC)
awieneke
JL
Thank you,
the stones (long time ago ) and the rendering i made in cinema 4d.
next time i try to import the stones into the symbols of ViaCad and test how it is usable for me.
Steve.M
#24 Posted : Sunday, October 12, 2008 9:22:21 AM(UTC)
Steve.M
Hi Andreas,
I find that strange unless there is some problem with the mac version with blending. Did you get any error popups while attempting to blend?
Could someone with a mac version please look at this, TIA
I was going to upload the model with the blends, but I keep getting an "upload failed" (maybe an unintentional limit on the vc3 files).
- Steve
awieneke
#25 Posted : Sunday, October 12, 2008 10:27:02 AM(UTC)
awieneke
Originally Posted by: Steve.M Go to Quoted Post
any error popups
- Steve
yes, two different error popups
please see the pictures
in the begining i used ViaCad 6, also with the mac version.
what do you mean with TIA ?
Steve.M
#26 Posted : Monday, October 13, 2008 3:39:56 AM(UTC)
Steve.M
That is just Thanks In Advance
I am seeing no problem with the blending with current beta. Maybe some update to the beta is resolving this problem?
I have been attempting to attach the model with the blends/rads, but I keep getting an upload failed, so I can only attach a pic.
awieneke
#27 Posted : Monday, October 13, 2008 5:02:53 AM(UTC)
awieneke
That is just Thanks In Awith the blends/rads
super, your blending looks how i want it.
Do you pick the edges in a certain order ?
TIA :)
Steve.M
#28 Posted : Monday, October 13, 2008 5:20:14 AM(UTC)
Steve.M
Yes, I blended the 4 intersections first:-
awieneke
#29 Posted : Monday, October 13, 2008 5:50:30 AM(UTC)
awieneke
no way in my file, probably you are right, it could be different to the mac version.
Steve.M
#30 Posted : Monday, October 13, 2008 6:02:59 AM(UTC)
Steve.M
I have been able to upload the model with the blends/rads as a compressed (zipped) sat file.
blending_p05_rads.zip (193kb) downloaded 5 time(s).
awieneke
#31 Posted : Monday, October 13, 2008 7:04:36 AM(UTC)
awieneke
Thank you Steve,
if it is not too much work, could you send me the file which includes the history ( features tree)
TIA :-)
Steve.M
#32 Posted : Monday, October 13, 2008 7:25:48 AM(UTC)
Steve.M
I have uploaded to uploading[dot]com
http://www.uploading.com/files/...ending_p05_rads.vc3.html
awieneke
#33 Posted : Monday, October 13, 2008 9:11:16 AM(UTC)
awieneke
I have uploaded[/url]
Thank you,
funny i can open your file with ViaCad 6 but if i try to open it with ViaCad Pro i get an errormessage: this file is damaged cannot read into application.
Anyway i can change the blending value in ViaCad 6
Hope the upgrade to viaCad_Pro_6 will come soon :-)
Steve.M
#34 Posted : Tuesday, October 14, 2008 7:39:34 PM(UTC)
Steve.M
I think it will be after the release of Shark LT.
You could look at the shark LT beta, yes,.. before you mention, beta software is not something everyone wants to use, but the current beta`s are actually for testing the current releases with bug fixes. It is not a case of new commands etc being tested, just a case of reported issues being fixed.
It would certainly help yourself to use the beta, and your feedback would also be from the current version, and help with finding problems.
There is a post http://forum.punchcad.com/showthread.php?t=1508 with links for the shark LT beta.
- Steve
awieneke
#35 Posted : Wednesday, October 15, 2008 2:00:15 AM(UTC)
awieneke
Thank you Steve,
for the link to shark beta,
the download is running in this moment and i will try to work with. I just bought ViaCad pro ( a kind of downgrade from ViaCad 6 ) and actually i have a to learn all the features it provides. in the special the great bendigtool ( bend along path ) i love and it is very usefull for me.
i become very fast familiarly with your software :)
i will tell you how i like shark beta
unique
#36 Posted : Wednesday, October 15, 2008 11:55:36 AM(UTC)
unique
Thank you Steve,
Yes Steve, your software is greeeeaaaat !! :D:D
bradcan
#37 Posted : Saturday, October 18, 2008 6:46:39 AM(UTC)
bradcan
Steve Your re-built file blends fine on the mac version. There are some small peculiarities however: If I select the entire model for blending only the top edges blend. If I blend the short edges first then select everything ViaCad hangs and has to be killed.
It is possible to get all sorts of errors if the short edges are not blended first because the blends of the other edges try to run into each other if the radius is greater than 0.1mm
Doing the blending in the order short edges, top, bottom then inner works fine.
Guest (17)
2 Pages<12
