#1 Posted : Tuesday, October 17, 2017 1:37:37 PM(UTC)
Was thanked: 319 time(s) in 212 post(s)
Good evening, anyone else have an issue with this? I'm running ViaCAD pro v10 with power pack. It's the English to metric conversion again. I've just put an offset in at 10mm and it's produced something that is 0.393mm gap, not 10.
I've put the offset in, then right clicked it in the tree and checked inspector attributes, and you can see the difference there.
If I change it in the inspector attributes it works fine.
#2 Posted : Tuesday, October 17, 2017 3:02:44 PM(UTC)
This is now fixed in the 1355+ builds.
Many thanks for reporting, there was a double convert going on...
#3 Posted : Tuesday, October 17, 2017 3:28:37 PM(UTC)
Awesome! Cheers
