cjohnson
#1 Posted : Friday, November 4, 2016 8:55:15 PM(UTC)
cjohnson
In ViaCad 2d/3d how do you precisely locate objects on a drawing?
For example: I draw a rectangle that will be a mounting plate. Simple enough.
Now I want to place a hole with a center 4 mm from the top edge of the plate and 4mm from the side of the plate.
How do you do this?
rokoko
#2 Posted : Saturday, November 5, 2016 12:11:39 AM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
hi, here is one possible way:
create construction lines (see pictures)
Edited by user Saturday, November 5, 2016 6:35:40 AM(UTC)  | Reason: Not specified
