macnavi
#1 Posted : Friday, July 22, 2016 8:31:11 AM(UTC)
macnavi
Netherlands
I can successfully use the Skin solid tool, but when I scale the grouped wires a bit larger, then I get an error "Wires must be either all closed or all open". Strange, because when I scale the group only a bit larger, there is no problem. Only when I do it even larger, suddenly the group is not closed. See video and attached file.
https://youtu.be/WwxGMs41ZqU
This is both in ViaCad 8 and 9.
Posthoorn 03.vc3 (1,963kb) downloaded 11 time(s).
