Morphin
#1 Posted : Tuesday, June 7, 2016 3:38:15 PM(UTC)
Morphin
Hi
I have succesfully used the shell command on a solid. Saved and opened later. Now i would like to change the wall thichness or maybe remove the shell completely. How do i do this if i can't "UNDO" anymore?
thank's for a hint :-)
Andy
murray
#2 Posted : Tuesday, June 7, 2016 9:08:50 PM(UTC)
murray
If you don't have access to the Concept Explorer, with which you select your object and undo shelling by high-lighting the shell feature, right-clicking and "delete feature", you can convert your object to surfaces, delete the inner surfaces and edges, then thicken the outer, or, if it's a closed shell, delete the inner faces and stitch the outers back into a solid that can be re-shelled.
Edited by user Tuesday, June 7, 2016 9:24:57 PM(UTC)  | Reason: Not specified
Craig
#3 Posted : Wednesday, June 8, 2016 12:00:53 AM(UTC)
Craig
You can use the push/pull tool to adjust the size or close up the shell completely.
BillB
#4 Posted : Wednesday, June 8, 2016 12:59:21 AM(UTC)
BillB
Select your object, then in the inspector select the right hand icon, Object Properties, this gives you a list of faces and their wall thickness. Selecting one face in the list will highlight that face on your drawing. You can change the wall thickness in the input box above the list. Setting the wall thickness to 0 will give you an open face.
Bill Bedford
Viacad Pro 11 (11417)
OS X 10.13.6
Morphin
#5 Posted : Wednesday, June 8, 2016 5:43:36 AM(UTC)
Morphin
Hi
Wow. So much help. Thank you very much for every person how is reading this!! I will try and report back.
Thank's again
Andy
