Thanks: 95 times Was thanked: 69 time(s) in 39 post(s)
Hello,
Is it possible to put a weld between two solids easily? I not mean "welding symbol" but a weld face in a 3D mode - have a look at the jpg attached and sfx file.
Best wishes
magicart
profiles.sfx
(969kb) downloaded 12 time(s). magicart attached the following image(s):
(149kb) downloaded 21 time(s). You cannot view/download attachments. Try to login or register.
I did it, but it wasn't easy and free of bugs :-(
magicart
(333kb) downloaded 37 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: magicart I did it, but it wasn't easy and free of bugs :-( magicart
Wow I am not sure I have even seen a robot make such precision welds.:)
Look good !
Hello Jason, I suppose a robot would do this even faster in real than I've been doing it in Shark :-) Thanks for your comment Magicart
Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
wow! Tim? possible to add a blend tool with weld look? Good idea? no? Antoine
Thanks: 34 times Was thanked: 50 time(s) in 37 post(s)
Antoine & Magicart, I like that idea. 8) Mike
We must ask Tim is that tool is on the long list of V10 improvement? :-) Magicart
Thanks: 153 times Was thanked: 149 time(s) in 102 post(s)
I have used Inventor for welds, but sometimes it's not easy, even using a
program that has had welding for quite some time.
Enclosed are a few examples that I hope SharkFX can include in Version 10.
A radius on the tubing seems to help.
Edited by user Monday, May 9, 2016 6:29:17 AM(UTC)
(27kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Hello Larry, So these welds you attached was created in Inventor? If Shark could do this in similar way, I would be satisfied. Magicart
