On the attachment I am trying to modify the top horizontal face of the solid (it's the face with the blue inspector area sticking out). I would like to make the face slightly convex with a slight x and y roll to it. May .10 to .20 inches. I am using Via Cad 2D 3D V8 on a PC. Any suggestions. Thanks.
Edited by user Sunday, November 8, 2015 8:38:21 AM(UTC)
| Reason: Added Via Cad File
Curved Block.vc3
(653kb) downloaded 12 time(s). jprevj attached the following image(s):
(31kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
You are looking for a beading like this ?
It's a half pipe following a copy of your shape.
A better way would be to pull up the contour and then hollow it with your values. If the bottom is then lying to deep, you can pull up it separately a bit.
Wether this runs on your version I don't now. I use V 9 Pro
horst.w, GER
Edited by user Sunday, November 8, 2015 3:58:30 PM(UTC)
(22kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
You want to change the shape of the top surface, so you should use remove face to take off the edge blend fillets around it, since they won't have continuity with the new surface's shape. Hold shift while you select them together. You haven't given a specification for the curved surface, so I used an arbitrary conic curve and lathed it to make a solid that envelopes the original part, then intersected the two. Then reapply the blend to the edge.
Edited by user Monday, November 9, 2015 4:30:19 PM(UTC)
Curved Block7.sfx
(818kb) downloaded 10 time(s). Curved Block7.sfx
(818kb) downloaded 5 time(s). murray attached the following image(s):
(67kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
Thanks! I will give these a shot.
