Thanks: 7 times Was thanked: 4 time(s) in 4 post(s)
Tim,
Minor suggestion for VIACAD 2D/3D and PRO V9...
It would be nice if we had the option to have some of the "View" menu items in an onscreen toolbar. I am referring only to the predefined views themselves, not every item in the View menu. I do use the keyboard shortcuts, but a toolbar option would still be nice. Same goes for the Workplane menu. This is not a priority issue for me, just a matter of convenience.
The Other Tim
Edited by user Wednesday, May 13, 2015 8:03:46 AM(UTC)
| Reason: Clarify text.
Tim (NOT Tim Olson) ViaCAD 2D/3D and PRO V9 1184, Blender 2.49-2.78. Win 7 SP1, Core I5, 64-bit, NVIDIA G105M
Thanks: 184 times Was thanked: 159 time(s) in 109 post(s)
Hi Tim, I don't have ViaCAD, but use Shark, and in the lower right corner of the Navigator there is a view button or view menu. Larry
1 user thanked L. Banasky for this useful post.
Hi Larry,
Thanks for the suggestion, but methinks I might not have a Navigator window in VIACAD. :(
I'm sure the Shark series you are using has several things that VIACAD does not.
I also edited my post above to clarify that I am referring to VIACAD. While I find VIACAD to be quite powerful, it maybe can't quite swim with the SHARKS in some respects! :-)
Happy Modeling!
The Other Tim
Edited by user Tuesday, May 12, 2015 8:56:50 PM(UTC)
Thanks: 8 times Was thanked: 76 time(s) in 38 post(s)
WaveMechanic,
Enable the Navigator through the Short cut keys. Select Window -> Navigator then set a key.
This is an undocumented feature, give it a try. Should be part of the program.
Mitch
mitchb attached the following image(s):
(83kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked mitchb for this useful post.
Mitchb and Larry, Hah! Success! I now have a Navigator window thanks to you two. Now methinks VIACAD *can* swim with the SHARKS. While I'd still like a few preset icons in a toolbar, this is a pretty darn cool for a hidden feature. Thanks again! The Other Tim
