I'm trying to define a part with the user defined mass property. It has a density of 0.16 g/CC. (Balsa-wood) When I click OK, and then go back in to look, its set to 160.00 g/CC If I chose a predefined material it works. Is there a way to create my own materials? TIA, Dave (Shark FX v7)
>>Is there a way to create my own materials? Hi Dave Look at the Materials.ini file in the Environ folder. You can add your own materials using this file. Tim
