rjs
#1 Posted : Friday, February 6, 2015 4:20:14 PM(UTC)
rjs
I am using ViaCAD beta 9.0.4 build 1150 (I have experienced this issue with the previous releases as well) and I seem to have a a low level of success converting STL files to solids. At least the binary tools do not work with them after the conversion. I select the object, right click, select change object type, select solid and click OK. The wait cursor spins for a while and stops with no errors but does not seem to change the object. I attached is a sample file of what I am talking about.
Thanks for any help!
Randy
Edited by user Friday, February 6, 2015 4:23:02 PM(UTC)  | Reason: Not specified
Tool Chest.vcp (196kb) downloaded 7 time(s).
#2 Posted : Saturday, February 7, 2015 3:57:58 PM(UTC)
Hi Randy
The limits of the Change Object Type tool inspired me to start the PowerPack project. Change Object Type will convert a single body perfect mesh of limited facet counts. Below is a video showing how I would use PowerPack to convert this mesh into a precise solid.
http://www.csi-concepts....emo/videos/toolChest.mp4
Edited by user Sunday, February 8, 2015 12:14:04 PM(UTC)  | Reason: Not specified
bronc3buster842001
#3 Posted : Thursday, February 12, 2015 3:31:19 AM(UTC)
bronc3buster842001
Im using the beta version and I dont have the option to check a mesh for non-manifold faces..
#4 Posted : Thursday, February 12, 2015 4:38:28 PM(UTC)
I just added that into the 1151 build which is not out yet for beta. Show Free Edges and Show Non-Manifold Edges really help track down problem areas for converting meshes into precision solids.
