Solid Modeling
Add Solid Retains original Parts
When I split a solid and use the "add solid" command I end up with 3 parts. I found it on my fairly complex parts and confirmed it on a rectangular extruded solid. Is this a bug or a new feature? Art FX 9.02 Mac 10.10.1
Can you post a short file?
Does this not happen to you?
I am on 9.0.2 1143
Art
Edited by user Friday, January 16, 2015 10:24:11 AM(UTC)
FinderScreenSnapz002.mov
(1,581kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
I don't think this is a bug but rather a setting that is backwards. If you look at the add solid command under the inspector-> data you can see if the hide parents is active. This is a new feature where you can go back and unhide the originals for whatever reason. In your case the two pieces.
I see! Thanks for the help. So the default is set to show parents. I assume I can see my personal default to hide them, correct? Art
Hi Art The default should be set to hide parents. Tim
Thanks Tim, nice to have a choice. Art
Solid Modeling
