rokoko
#1 Posted : Monday, January 12, 2015 1:52:00 PM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
hi all,
during work with viacad/shark i sometimes come upon cases that could have need of a bit improvement in handling.
e.g.
- gripper activation: currently there are 3 ways to activate gripper
(shortcut and menu/modify -> both will activate gripper tab in inspector,
contextual menu -> without gripper tab activation in inspector)
to my mind there is no need for the shortcut to activate the gripper tab in inspector, because usually you want to see object properties in inspector
- contextual menus: some helpful commands could be added (see pictures)
what do you think about?
