Thanks: 13 times Was thanked: 13 time(s) in 10 post(s)
                When extruding text with draft, the whole process with a sentence fails when a letter has a hole in it, like R, O, P, A or when the draft is too high that both sides of the leg of a letter would overlap it each other. It brings up the error: "ACIS error: Rigid sweep with draft". I don't mind if they would overlap.  Is there something I can turn off so that it allows me to overlap the draft? Like you can do Pipe options, "Allow Self Intersection". Using ViaCad 8 2D/3D (9 has still too much bugs to be functional) and Mac OS X Yosemite.
                One workaround is to extrude text with rhino3d and export as acis 4.........
just my 2cts
regards
- Bernd -
Edited by user  Monday, December 29, 2014 3:31:00 PM(UTC)
 | Reason: wrong acis version number
                Try converting the text to curves from object type than do each one individually.  There's a limit that draft can do with letters until wall will start to collide.  Maybe doing it individually avoids the error.
