Surface Modeling
Cut Section - Auto layer option
Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
I'm wondering how this is working. I did not manage to get this done. Is there a screencast some where showing how to get the cut section automatic into different layer. Thanks
Martin Krueger ViaCAD ProV9, Cut2D, Cut3D _myMill self made CNC milling-machine
Martin You need to hold ctrl down for auto layering when selecting the object. Regards
Martin After the tool has you select the infinite planes to cut object with hold down ctrl while picking the solid that is being cut. Regards Jason
Thanks to all. Now i get it and it works. Thanks
Is it possible, that multiple select when holding ctrl down is not possible?
Surface Modeling
