XL5
#1 Posted : Sunday, March 27, 2011 10:42:47 PM(UTC)
XL5
If you choose the tolerance style of 5.00".02" the Tolerance Text Size Doesn't Work. (The tolerance style that has the numbers "stacked" does allow their size to be changed.)
I have tried changing the tolerance size percentage in Dimensions > Standards Manager. It does nothing.
There is also a box in "Dimension Object Info" that reads "Tol Text Size". Changing the percentage in that window also does nothing.
using Mac OS 10.6 and ViaCAD V6 2D.
