                Hallo,
i draw a very simple ring and want to blend the edges.
But the result is very 'funy'
Please see the pictures.
awieneke attached the following image(s):
(63kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Go in your history, remove feature (right click), do undo. and voil it's magic!!
    METEORE DESIGN / KEKO Stand  Jean-Francois Jacques, Industrial Designer  SharkCad Pro V14 B1653  Platform macOS 14 Sonoma
                Go in your history, remove feature (right click), do undo... and voil it's magic!!
Jean-Francois Jacques attached the following image(s):
(39kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                I did the previous example with Shark FX beta V9. If you don't have success, try to change the resolution via the menu bar Edit/Change resolution/ Super Fine - Precise Facets...
                the 'remove and undo' workaround is not working in my ViaCad version 7. Also the change of the resolution makes no different.
                Go to a blank part of the screen and try right-clicking the mouse and then selecting Hide All > Curves . Martin.
                Originally Posted by: blowlamp  Go to a blank part of the screen and try right-clicking the mouse and then selecting Hide All > Curves . Martin.
this will not change my blending.
after changing this solid in an surface part, the thing is a surface.
(156kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Not sure what is it that makes the blend funny as your original quote.  Maybe elaborate more.  It seems you need to hide the points or curves as someone suggested so that you only have the solid.
Originally Posted by: awieneke  this will not change my blending. after changing this solid in an surface part, the thing is a surface.
                Originally Posted by: rockyroad_us  Not sure what is it that makes the blend funny as your original quote.  Maybe elaborate more.  It seems you need to hide the points or curves as someone suggested so that you only have the solid.
  o.k.
i copy the ring, paste it into a new document and the blending is as funny as in the original document.
Oh sorry, I totally missed what the real problem was and I can't explain where that surface is coming from.
Use the Select Deep tool to pick that naughty surface and press Delete to erase it.
However, if you save your job (minus the blend) as a STEP file and then open that STEP file, I found that the blend worked OK.
Martin.
                you need the precise facets checked in object resolution.  That worked for me to get rid of the surface that fills the hole.
                Originally Posted by: blowlamp   However, if you save your job (minus the blend) as a STEP file and then open that STEP file, I found that the blend worked OK. Martin.
Thank you,
as a step file, it works, but it loses the history, what i often use, for example, just to change the rings size.
                and on the bottom side it works ! i found it and it works :-) great ! edit > change resolution > precise facets Thank you
