ttrw
#1 Posted : Wednesday, May 16, 2012 7:24:48 AM(UTC)
ttrw
I'm sure VC once had 3DS export? What happened to that?? Or am I dreaming?
posh.de
#2 Posted : Wednesday, May 16, 2012 9:58:53 AM(UTC)
posh.de
Rank:: Senior Member
VC 3D v7/6/5 had no 3DS export, use OBJ instead.
ttrw
#3 Posted : Wednesday, May 16, 2012 4:46:42 PM(UTC)
ttrw
Nein!
OBJ is rubbish! Scheie!!
OBJ just ends in thousands of flipped normals that I haven't got the time for. It's a useless export function that many hate using- and I can see why. :mad:
#4 Posted : Wednesday, May 16, 2012 7:25:54 PM(UTC)
FYI,
When we export normals for OBJ they are extracted from the underlying BREP and should be the same as what you see on the display screen.
blowlamp
#5 Posted : Thursday, May 17, 2012 2:53:13 AM(UTC)
blowlamp
I get OK results with OBJ files into a CAM program I have.
Pics show the original from ViaCAD Pro in blue and the OBJ import into CAM in yellow.
Martin.
ttrw
#6 Posted : Thursday, May 17, 2012 3:02:50 AM(UTC)
ttrw
No worries, STL seems to work pretty well. (ViaCAD into Cheetah3D)
But I'm still confused why someone like Posh.de suggested OBJ, when a STL file is a far better solution? The problem with OBJ is that it spits out hundreds of segments that you then have to regroup, and it's a right pita if you are working with several layers...
ViaCAD render in C3D.jpg (186kb) downloaded 6 time(s).
ttrw
#7 Posted : Thursday, May 17, 2012 3:12:16 AM(UTC)
ttrw
Martin, just for the record, these are the outs from OBJ and STL. Just so you know.
Screen Shot 2012-05-17 at 10.05.33 STL.jpg (30kb) downloaded 6 time(s).
Screen Shot 2012-05-17 at 10.09.03 OBJ.jpg (79kb) downloaded 5 time(s).
ttrw
#8 Posted : Thursday, May 17, 2012 3:15:09 AM(UTC)
ttrw
Both are exactly the same part, but different file formats.
#9 Posted : Thursday, May 17, 2012 11:45:16 AM(UTC)
The OBJ file format allows specification of the normals per vertex. In our case the normals precisely represent the underlying surface from which they came from.
The STL file format does not allow for specification of the normals. That means any application reading this format will need to rebuild facet normals using approximate techniques.
ttrw
#10 Posted : Thursday, May 17, 2012 2:45:34 PM(UTC)
ttrw
Thanks for clearing that up Tim. :)
Either way, all I bothered about is being more productive when it comes to rendering. It's not just your software I've had problems concerning OBJ export. It's good that STL is a viable and doable option, and that's all I really care about. :)
Tom
ttrw
#11 Posted : Saturday, May 26, 2012 3:01:59 AM(UTC)
ttrw
Nope STL is no good either. Fine for small parts, but for more complex models, it doesn't retain the layer, or sections. I still have to use SAT, and go via Moi3D to export to 3DS. :(
