Solid Modeling
Acis error on fillet- Bug (#2378)
                Hello Tim,
I have posted before about the continuous errors being put up by VC. I have been looking at spaceclaim for some comparison.
On a model I was playing around with (from another thread) I was attempting to place a fillet on one of the inside edges. VC would not allow this with a popup of "Acis error" pic01
I then exported this model (Acis sat) into spaceclaim which had no problems with the size (or even bigger) of the rad pic02/pic03
I have attached the sat file of the model.
- Steve
 fillet.zip
(58kb) downloaded 5  time(s). Steve.M attached the following image(s):
(123kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Hi, Steve
I turned off chain select and checked feature interaction in options and it created a fillet with no errors. 16mm and 18mm see pics
ViaCAD 835
 filletVC.vc3
(263kb) downloaded 5  time(s). jdi000 attached the following image(s):
(35kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Hi Jason,
                Agree here Steve, Jason .. the perception from most users will be that it doesn't work
                Originally Posted by: jdi000  Hi, Steve
Hi Jason,
It's a credit to you as you know the product bugs and all, but why on earth should anyone need to do that in the first place, this program makes less sense by the day:rolleyes:
If this input was necessary I would expect the program to report an more meaningful error such as "turn on feature interaction you wolly"
                I am still trying to work out as to what "Feature" this fillet is interacting with, as it is an Acis solid. All the other programs I have simply made the fillet very quickly without error or problem, even Rhino made this fillet, and I started using VC because I think Rhino is not too good with fillets.
Solid Modeling
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
