Small problem?
Pic pd01 shows a simple shape being path duplicate on a circle, there is a second copy at the origin of the circle.
Pic pd02 also shows the second copy, but please note the orientation of the copies,.. this appears to be Dependant on the direction of the alignment, and the problem is only when taking alignment on the y axis (in this example)
currently running 790(PC)
- Steve
(30kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
A circle has a start point and and end point, They just happen to be the same point. When using path duplicate the software puts an incident of the object on the start point and the end point. This is why you are getting two incidents at the same point. The copies moving to the inside of the circle are related to the order in which you picked the two points for the alignment. Change the order of the points selecting the bottom point of the polygon first then the top and the incidents will be on the outside of the circle.
Todd Q CAD Support Specialist Encore Software/ IMSI Design
Todd Quinlan wrote: A circle has a start point and and end point, They just happen to be the same point. When using path duplicate the software puts an incident of the object on the start point and the end point. This is why you are getting two incidents at the same point.
I know what it is doing, but why,.. it is the first cad system I have used with this problem. Quite a lot of paths are closed for Path duplicate(array along curve) should there not be some check by the program for this?.
Todd Quinlan wrote: The copies moving to the inside of the circle are related to the order in which you picked the two points for the alignment. Change the order of the points selecting the bottom point of the polygon first then the top and the incidents will be on the outside of the circle.
As it only happens (in this example) with alignment direction selection on the Y and not the X, I question your logic.
I would expect the alignment direction to either:-
The alignment direction to show the actual direction of the object as following the path
Or,
For the alignment direction to specify the side of the path the object is to be placed
Another simple example:-
pic01 /pic02 attached
(27kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Fixed in 792--alignment angle issue and duplicated overlaps. Tim
Tim Olson wrote: Fixed in 792--alignment angle issue and duplicated overlaps. Tim
Many thanks Tim,
792?... have I missed 791?.
You are certainly pushing out these bug fixes,... excellent.
Regards,
- Steve
>> 792?... have I missed 791?. The 790 build is still the most current for ViaCAD 2D/3D V6. Will have another patch next week. Tim
Hi Tim,
Tim Olson wrote: Will have another patch next week.
No rush, there may be other bugs/oddities found.
Regards,
- Steve
Tim Can we get the duplicate removed in the dynamic linear array tool as well? Thanks Jason
Tim, I can't remember there being a preview facility in the array tools (so for eg one can get an idea of where repetitions may fall, as I increase or decrease their amount or size). Can a possibility of adding this feature also be addressed sometime? (It would be also nice a have this feature with fillets and chamfers also :) ) Tom
