Suggestions
Copy from Verify Distance (#3137)
                Early versions of CU allowed users to copy and past dimensions from the Verify Distance window into other fields. This has been missing for a while now and is a big inconvenience. Every few minutes I find myself measuring something, then need to change an objects length to that dimension, add that dimension to something , or subtract it are. A simple copy and paste would make life so much easier. How hard could it be to make the text in this window selectable ?
    Shark FX 9 build 1143
OS X 9.5
matter.cc
                Originally Posted by: NickB  Early versions of CU allowed users to copy and past dimensions from the Verify Distance window into other fields. This has been missing for a while now and is a big inconvenience. Every few minutes I find myself measuring something, then need to change an objects length to that dimension, add that dimension to something , or subtract it are. A simple copy and paste would make life so much easier. How hard could it be to make the text in this window selectable ?
I guess this must be a mac bug because all fields copy and paste in the verify distance pt to pt in Windows all builds I tried.
All verify tools seem to work on windows.  Except for verify length and perimeter.  It would be nice if all these tools would have fields that could be copied.
                It has been suggested before, but it would be really handy if there would be an option to save the line that is shown as minimum distance. By the way, I can confirm that  the dimension in the verify distance dialogue box cannot be selected/copied in the Mac Version of SharkFX. Would be nice to fix this soon. Ciao, Norbert
Suggestions
