misterrogers
#1 Posted : Thursday, February 25, 2010 10:29:08 PM(UTC)
misterrogers
Is there already a command to "transform again"?
e.g. If a line is moved over a specific distance, can I click on another arbitrary object and click "transform again" so it too moves that distance from wherever it is?
zumer
#2 Posted : Friday, February 26, 2010 3:50:07 AM(UTC)
zumer
I don't know, but I think it would be only slightly more efficient, and only if done with a transform record option key. It takes shift and two mouse clicks to shift the selection focus anyway, and then two more clicks for origin and destination. A "transform again" button would save one click, and you'd have to shift your attention from the drawing window to the toolbar and back.
NickB
#3 Posted : Friday, February 26, 2010 11:15:09 AM(UTC)
NickB
Unless I am misunderstanding you, this works already.
Select the transform / move tool, select your object, click point to move from, click point to move to. After the move the object and tool are still both selected so you can easily just click start and end points again. If you want to duplicate press the option key. This has been working for me for years.
Shark FX 9 build 1143
OS X 9.5
matter.cc
misterrogers
#4 Posted : Saturday, February 27, 2010 10:09:10 PM(UTC)
misterrogers
I'm referring instead to being able to select a second object immediately after transforming a first object.
e.g. if I want to rotate an object 35 on the X axis, it would be handy to select another object immediately after and be able to hit a shortcut key that would transform that second object 35 without having to enter the numeric value a second time.
Is what you have suggested a possible solution to this?
Thanks.
zumer
#5 Posted : Sunday, February 28, 2010 12:50:38 AM(UTC)
zumer
I found it can be done if you take care with the deselection and reselection of new subjects so that the delta figures in the program header don't change and the program isn't interpreting the selection clicks as a new move. If they're unchanged, and you've changed the selection focus successfully, pressing enter will apply the transformation or translation according to the figures in the header. A little fussy, a lock for the delta figures would make it work consistently.
zumer
#6 Posted : Sunday, February 28, 2010 12:58:48 AM(UTC)
zumer
I've found that I can make it happen sometimes, if I take care shifting selection so that the delta figures in the program header are unchanged, then press enter. Sometimes it works as you'd want, sometimes the second action undoes the first as well. Not reliable or consistent, so not a time-saver.
#7 Posted : Sunday, February 28, 2010 11:52:54 AM(UTC)
A temporally select tool it will be helpful for this, so you can back and for between tools just pressing and depressing one key
MacOSX Ventura 13.6.4
