Having a SCALING issue in Model-to-sheet (#3067)
When I select my 3d model for model-to-sheet, I input 0.125 for 1/8 scale which it does. The problem I face once I get the orthogonal views on the sheet, is that when I dimension it, the dimensions are 1/8 the size.e.g. a table top that is 400 mm wide, now shows up as 50 mm. Obviously I can keep it at a 1:1 scale, but that wouldn't fit on the tabloid size paper. So..... how can I scale the image down 1/8, but allow the measurements to read correctly at full-scale? What am I doing wrong? I'm stuck and I need to do this asap :( Thanks!!!
Originally Posted by: misterrogers When I select my 3d model for model-to-sheet, I input 0.125 for 1/8 scale which it does. The problem I face once I get the orthogonal views on the sheet, is that when I dimension it, the dimensions are 1/8 the size.e.g. a table top that is 400 mm wide, now shows up as 50 mm. Obviously I can keep it at a 1:1 scale, but that wouldn't fit on the tabloid size paper. So..... how can I scale the image down 1/8, but allow the measurements to read correctly at full-scale? What am I doing wrong? I'm stuck and I need to do this asap :( Thanks!!!
Hi
Let the program scale when you want to print ie draw everything the way you want in or out of draw views. If you keep the draw views they will scale the dimensions for you. until you flatten them, so don't flatten then if you want to dimension them or change them they can stay as drawviews.
Print fit to page or scaled value
Remember the following
print 1:1 text and lineweight print as set
if you print 1:2 your text will be 1/2 as high and your lineweight will be half what its value is.
so your text and lineweight scale to the print setting so plan accordingly if you need a certain text height or lineweight printed.
(16kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Thanks Jason I should have tried that first.. common sense i've heard.. is not so common after all :)
