misterrogers
#1 Posted : Monday, February 6, 2012 2:16:51 PM(UTC)
misterrogers
How can I properly add Medium Density Fiberboard to the properties box?
I need to be able to calculate the weight and density of MDF but am not sure how to "add" this so it will remain a selectable option from here on.
Any ideas?
Jean-Francois Jacques
#2 Posted : Monday, February 6, 2012 5:32:15 PM(UTC)
Canada
Through your Materials.ini file. Application/Shark Folder/Environ.
Make a copy before...take a look in the file and you will understand. You only need the MDF Density...Or tell me the density and I will do for you.
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
#3 Posted : Tuesday, February 7, 2012 9:34:53 AM(UTC)
Canada
It is difficult to target the MDF Density, because is depend of the thickness. A good average is 700Kg/m3 (.02528911 pound/Cubic inch).
Included the .ini file. I don't know if the file is good for ViaCad, is modified from Shark FX.
Materials.ini.zip (2kb) downloaded 5 time(s).
Jean-Francois Jacques attached the following image(s):
#4 Posted : Tuesday, February 7, 2012 12:28:13 PM(UTC)
This ini file format works for all punchcad products.
phil
#5 Posted : Tuesday, February 7, 2012 2:11:34 PM(UTC)
phil
Re: 6 or 8 decimal places
Tim, inside the .ini file it says "...max of 6 decimal places" but in the Shark software it looks like 8 decimal places (because i tried 9 and it rounded it to 8 places). Is it 6 or 8 decimal places max? Thanks.
phil
#6 Posted : Tuesday, February 7, 2012 2:59:11 PM(UTC)
Canada
In Shark is the same.... max of 6 decimals
#7 Posted : Tuesday, February 7, 2012 8:35:18 PM(UTC)
I checked the code and see that it is reading and storing a double precision value for the density. So that means it has 16 total digits of precision. 16 digits to store the whole and decimal part. The ini file mentions 6 decimal places, I suspect that is in regards to our ACIS kernel which uses 0.000001 inches as the same point tolerance.
misterrogers
#8 Posted : Thursday, February 16, 2012 8:57:26 PM(UTC)
misterrogers
Works great! That's what I was looking for many thanks for the file.
