Problem with DynWorkPlane (#5193)
Thanks: 3 times Was thanked: 4 time(s) in 3 post(s)
Hello
since i changed to Viacad 9 Build 1109 i do have tones of DynWorkPlanes. And i'm wondering where the are coming from.
Martin
martinwh99 attached the following image(s):
(438kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Martin Krueger ViaCAD Pro V12 PowerPacked, Cut2D, Cut3D _myMill self made CNC milling-machine
Hi Martin I have not heard of this one. Are you seeing this when opening a new file or is this unique to a specific file? Tim
I am seeing this issue as well. When I open, for instance, "Paper towel.vc3" bunch of DynView sub items are added to the user view sub menu. If I close and re-open it, I see that more DynView items were added. If you repeat this you will have a pile of DynView as in the screenshot from the OP. This happens for some files. Paper towel example is one of them. Some of the tutorial files also are like this. But for instance beveledgear.vc3 does not seem to cause this issue. Hope this helps. edit: I am on v9.0.0 - Build 1104. Windows 7.
It happens with an existing file. But if i open an new one same thing. Win8 64bit v9.0.0 - Build 1109
>>edit: I am on v9.0.0 - Build 1104. Windows 7 Can you update to 1109? We made some good corrections between 1104 and 1109. You can update from the Help:Current Version menu. I'm currently working on build 1129. We have enough corrections where I will be providing another update to all products in about 30 days. Tim
