jonah
#1 Posted : Saturday, December 29, 2007 9:23:44 AM(UTC)
jonah
i would like to know if there is a way to make the text larger when i dimension components. i have not been able to increase the font size of the measurement. thanks. jonah.
#2 Posted : Saturday, December 29, 2007 10:52:13 AM(UTC)
You can right click and make it bigger from the size menu
You can set a bigger default by selecting nothing, then changing the dim size from the dim menu whilst in the dim tool
You can copya text font/size/style using the pipette tool
BUT you cannot change the attributes of the text in the attributes tab of the Object Edit Box
Which is exactly where you'd expect to change an object's attributes
I have asked all Godly and outer-terrestrial bodies .. nobody knows why this is
