Import/Export
DWG Import Paper Space to Draw views don't have dimensions connected to draw views (#1257)
When dwg's are imported the paperspace is converted to draw views works good. But the dimensions are not embedded in the draw view they are separate entities so when you go to move the draw views you cannot get the dimensions to stay with them? Is this expected or not expected.
Viacad v6 784
Vista
dwgwithpaperspace.vc3
(18kb) downloaded 5 time(s). Drawing2.zip
(11kb) downloaded 5 time(s). jdi000 attached the following image(s):
(24kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Interestingly enough, I get this if I sketch, then dimension in QCad, and then import into AutoCAD. However, I just tried this with QCad and VC, and got this result (1 image is QCad, other VC.)
I think everything would be okay, if VC would only remember my font and arrow settings. (then again, they look 'inversed' :eek:) :mad:
(8kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Import/Export
