[URL="http://www.techsoft3d.com/our-products/hoops-publish"]HOOPS Publish SDK[/URL] free [URL="https://itunes.apple.com/us/app/hoops-viewer/id457991468"]HOOPS Viewer f. iOS[/URL] free [URL="https://play.google.com/store/apps/details?id=com.techsoft.hoopsviewer"]HOOPS Viewer f. Android[/URL]
i tried the Tetra 4d plugin for acrobat xi, the plugin is built from hoops sdk. if VC/Shark could export the native 3d formats readable by xi (prc or u3d 3rd ed) then we wouldnt need any special sdk or have to pay for plugins.
here's a sample PDF, should be viewable in reader v8 and above.
so for the VC/Shark developers, can you get a u3d or prc export into your product??
i am trying to export from blender a u3d for xi, but xi keeps telling me there is a parsing error...... and error because this export plugin is not the same as u3d used in PDF's.
test_blank.pdf
(103kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
MeshLab converts to U3D, or check out 3dpaintbrush.com. 3dpaintbrush has been abandoned, but Geometric are kind enough to offer it gratis. It's pretty good, but its 3D pdf export combined with metallic shaders causes crashes.
thanks Zumer, i found MeshLab last night and it worked fine.
some of the install files for VC have "hoops" in their names, not really sure what hoops stuff VC uses, but, VC/Shark should be able to (need feature) export PRC or U3D that Acrobat can use, at least this would give us the basics to placing a 3D item inside a PDF w/o the added costs of a pay-for plugin.
here is sample Gear file from VC9, exported as STL, imported into ML, exported as U3D, inserted into PDF.
blank.pdf
(39kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
