Redss
#1 Posted : Friday, January 16, 2009 8:11:38 PM(UTC)
Redss
Help on making tiles into STL an easy way to make all the tile in the lay out.
Or do I have to make each tile then set it into the lay out
Tile Floor_2.vc3 (21kb) downloaded 5 time(s).
Redss attached the following image(s):
Tile Lay Out.jpg (95kb) downloaded 5 time(s).
Tile Lay Out_2.jpg (50kb) downloaded 5 time(s).
STL Tile 7.8125 x 7.8125.jpg (39kb) downloaded 5 time(s).
Tile 7.8125 x 7.8125.jpg (34kb) downloaded 5 time(s).
#2 Posted : Saturday, January 17, 2009 12:53:28 AM(UTC)
Hi, Redss
Did you try using the linear duplicate tool? You could array a pattern of tiles and then lay them in the layout of the room, rotate or move them as needed Then you can use add solid and add all the tiles together and them using the outline of the room and then use cut solid to trim the tiles to fit the room where they are only partial tiles.
tiles.vc3 (871kb) downloaded 5 time(s).
Redss
#3 Posted : Saturday, January 24, 2009 5:02:57 PM(UTC)
Redss
Hi jdi000
That worked great
I am not sure what I did now
I used Add Solid to the tiles to cut the out side
Now I can not unlock them :confused:
Redss
#4 Posted : Saturday, January 24, 2009 5:34:24 PM(UTC)
Redss
Could you help me
The bathroom I made in ViaCad when I put it into a STL File and put it into E-Cabinets the hole room is backwards:confused:
When I made it I set it up so when you hit TOP you are looking down from the ceiling at it.
EC_Our bathroom_1.JPG (124kb) downloaded 5 time(s).
