la mouche
#1 Posted : Wednesday, February 4, 2009 9:34:24 AM(UTC)
la mouche
hello,
Here is a problem since CU sp3. (see attachments)
Procedure:
-export IGES solid model with CU and SHFX
-IGES import in the software 3DesignCAD
conclusion:
exports:
-CUsp3
format: .Iges are correct in 3DEsignCAD
exports:
-CUsp4,
-SharkFX 5.0 750
-SharkFX 5.5 819
format: .iges are not correct in 3DesignCAD====> Visible ripping and parents (boolean subtraction sphre) visible.
Tim? you have a solution?
To resolve this problem, I have to keep an old version sp3 :confused:
Thank you in advance.
Antoine
test exp..zip (478kb) downloaded 5 time(s).
